new Lingenfelter tpi 58mm throttlebody
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I have a new lingenfelter 1000cfm 58mm throttlebody it has the airfilter piece as well and gasket $315 FIRM !!! shipped to the lower 48 $330 to canada . The throttle linkage is for 89-92 tpi. but will work on 85-92 tpi with throttle cable change. still in plactic never opened
Last edited by Tuned Performance; Oct 18, 2011 at 03:56 PM. Reason: new lingenfelter 1000cfm 58mm throttlebody
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Re: new accel tpi 58mm throttlebody
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT Thats weird
Engine: Lb9
Transmission: M20
correct, My camera is broken, same item but I have the airfilter adapter and gasket
Engine: Lb9
Transmission: M20
updated picture through my ipod !!!
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Does it come with any sensors? And do you take Paypal?
Thanks,
Jon
Thanks,
Jon
Engine: Lb9
Transmission: M20
No sensors, you will needs a throttle position sensor and the idle air control. and yes I do take paypal !!
Car: '83 Berlinetta
Engine: 383 CI
Do you know if I can transfer across my 52mm BBK sensors?
Jon
Jon
Engine: Lb9
Transmission: M20
Yes you can, The bbk uses the idle air control and lower plate from the stock gm rochesther throttlebody, as well as your top plate. Depends on what you would want for the bbk I might be intrested, maybe I can buy it from you after you get his one all setup?
Engine: Lb9
Transmission: M20
ttt selling out my old stock 3 left
Engine: Lb9
Transmission: M20
feedback would be nice !!! am I overpriced. Was thinking this was a decent deal for new parts that are discontinued ? ? ? ?
Car: 89 Formula
Engine: 383 SBC/HSR
Re: new Lingenfelter tpi 58mm throttlebody
1000cfm 58mm throttle bodies are usually used on big blocks. Only problem is most people running big blocks are using a different intake/setup thus eliminating the need for this TB. 1000cfm is great, but the intake is usually where the restriction is.....that might explain why they discontinued the item? Who knows.
I would definitely lower the price......hope this helps your sale.
Car: 1989 IrocZ
Just to bump this for you you should explain its a billet piece. As nice as the Holly unit is, this one puts it to shame by a long shot in terms of looks hands down best tb ever made for the tpi, looks killer on a super ram which I've had it on twice. Hope this helps.
Car: 89 Formula
Engine: 383 SBC/HSR
The reason I said that is because I don't see a 350 or 383 needing 1000cfm....it's just overkill. TPI intakes bottle-neck right after the TB. There have been several, high hp, build-ups posted in numerous articles making 500hp with a ported 48mm.
However, it definitely looks nice.....no argument there.
Car: 1989 IrocZ
I should have said not on a stock tpi, this is the second superram I've had it on and one on a miniram. Would def be a waste on anything else. I went 12.6 at 111 with a 48, but is was with 9lbs from a procharger
Car: 89 Formula
Engine: 383 SBC/HSR
Engine: Lb9
Transmission: M20
Thanks for the help guy's the 85-88 is still availabe. but the idle air passage on this will allow it tobe mounted on any tpi or superram plenum. offers welcome, could use the cash. I'm hoping people will leave me feedback soon. I know how leary it is to shell out much money hoping your item will show up !! I am honest hopefully my feedback will show it soon..
Engine: Lb9
Transmission: M20
$315 shipped to the lower 48 !!!
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Engine: Lb9
Transmission: M20
I just dropped the price . I don't think I want togo any lower
Engine: Lb9
Transmission: M20
great for those super rams or hsr
Car: '83 Berlinetta
Engine: 383 CI
I'm in Canada so my shipping is going to be more expensive. Assuming at $280.00 your leaving yourself $20-30.00 for shipping costs, would you do $250.00 plus shipping up north?
Jon
Jon
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
freee bump:
by the way my 383 lingenfelter. super ram 1000 cfm tb eng ran 11.70s
without boost and was 50 state smog ok.
and that was 15+ years ago..
get one..
get one..
Engine: Lb9
Transmission: M20
Thanks again, jon
Car: '83 Berlinetta
Engine: 383 CI
Works for me. PM your Paypal please I will be able to get that to you tonight or tomorrow night.
Jon
Jon
Engine: Lb9
Transmission: M20
ttt nice billet piece New !!!
Engine: Lb9
Transmission: M20
ttt
Engine: Lb9
Transmission: M20
heck of a deal for a billet 58mm new throttlebody
Engine: Lb9
Transmission: M20
Price is firm, I won't reply to low baller's !
Engine: Lb9
Transmission: M20
Sale Pending !!!
Engine: Lb9
Transmission: M20
I Do not see why it wouldn't, the throttle shaft is in the exact same placement as a stock one.
