hypertech thermomaster chip for sale cheap
Car: 1989 gta
Engine: 5.7 ltr
Axle/Gears: 9 bolt 3.27 limited slip
i have a hypertech thermomaster chip for sale for $50.00 shipped anywhere
the part number is 128922 and the sn# 151282 ITS FOR 89 CAMARO/FIREBIRD 350 automatic without v.a.t.s (c) code. I spoke with hypertech and they said they have seen gains of 15 to 20 hp and 20 to 25 tq from these chips for 20 years so they do work. I can't use it because it's not the right one for my car.these chips retail for over 200 bucks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: hypertech thermomaster chip for sale cheap
Did someone reprogram out the vats? The last 128922 I had had vats selected on it.
Car: 1989 gta
Engine: 5.7 ltr
well it doesn't work with my computer i need an x code chip i asked hypertech and they said it was because gm added vats in the middle of the year and my vehicle had it, so there are 6 different chip codes for that year and this one is (c)
Engine: Lb9
Transmission: M20
the is a vats select in the programming the resister code is not determined by the memcal programing but by the vats module. The vats module are matched to the different key resisters.
Engine: Lb9
Transmission: M20
did you get a code 51 when installed or something ?
Car: 1989 gta
Engine: 5.7 ltr
i never installed it hypertech said it wouldn't work they said it would start then kill right away
Engine: Lb9
Transmission: M20
(if you have vats it will work) in a 1227165 ecm it uses $6e programing. who ever you talked to is uninformed . you should go grab a 7mm nut driver and a 5/16 wrench disconnect you battery and install it. You'll have it swapped out in 15 min or less.
Car: 1989 gta
Engine: 5.7 ltr
i gave them he four letter code off the stock chip and they said the one i have is not compatable i need a xdr 3176 128922 chip, the one i have is a (c) code i need an (x) code
Car: 1989 gta
Engine: 5.7 ltr
well i put it in and it worked great in fact i felt a noticable difference thanks man
Engine: Lb9
Transmission: M20
If you want to sell the stock one let me know.
Engine: Lb9
Transmission: M20
Sent the $45 for the stock memcal. Thanks again
evilstuie
Apr 14, 2016 08:52 PM
NBrehm
Aug 25, 2015 11:49 PM
