Mufflex muffler & tail pipes, stock Z28 Panhard Bar, LCA's
Subscribe
Jan 30, 2012 | 10:52 AM
ALL SOLD. THANKS!
Basic T-56 trans crossmember SOLD
Also:
Pair 1LE rear calipers + brackets
Axle mounting brackets
Brake hoses
Hawks pads with +75% life
pair rotors (still have some life, but do recommend replactment)
asking $275 for the kit but will accept offers. ($250 without the rotors) SOLD
I have a Borg Warner 9 bolt forsale out of my 87 iroc. It has approx 125k miles on it. The posi clutch packs are all the way bottomed out and has 3:23 gears. There was no bearing noise before i pulled it. No metal chunks in the fluid either. Just needs to have the clutches redone. I will throw in The calipers and brake hoses if you want them but theyre no more than cores.
Located in northeast CT.
GONE
Reply 0
Jan 30, 2012 | 05:02 PM
Re: BW 9 Bolt FS 3:23 posi
Quote: I have a Borg Warner 9 bolt forsale out of my 87 iroc. It has approx 125k miles on it. The posi clutch packs are all the way bottomed out and (should be) 3:23 gears. There was no bearing noise before i pulled it. No metal chunks in the fliid either. Just needs to have the clutches redone. I will throw in The calipers if you want them but theyre no more than cores.
Asking $150 or reasonable offer? Pickup only please
Im mildly interested as im in the market for a rear end.
Why should the clutch packs be bottomed out?
Reply 0
Jan 30, 2012 | 05:29 PM
The Clutches are bottomed out meaning that the unit is no longer positraction. It would need to be rebuilt for functioning posi, but works fine and has no issues driving as an open carrier.
Reply 0
Jan 30, 2012 | 09:51 PM
Quote: The Clutches are bottomed out meaning that the unit is no longer positraction. It would need to be rebuilt for functioning posi, but works fine and has no issues driving as an open carrier.
Thanks for the clarification. Let me see how much it will cost to have it rebuilt and if it makes sense I will touch base with you.
Thanks.
Reply 0
Jan 31, 2012 | 07:56 AM
Ebay clutches. Theres a thread on here about the rebuild
Reply 0
Feb 1, 2012 | 08:59 PM
Re: 1LE Rear brakes, T56 X-member, BW 9 Bolt FS 3:23 posi
bump! added 1LE brakes and a tranny crossmember!
Reply 0
Feb 1, 2012 | 09:38 PM
Pic of the rear brakes?
Reply 0
Feb 1, 2012 | 09:44 PM
Quote: Pic of the rear brakes?
Ill get one up first thing in the morning
Reply 0
Feb 1, 2012 | 10:58 PM
1LE brake kit in working order? also do you have the emergency brake cable too or did you keep that on the car?
thanks, Tim
Reply 0
Feb 2, 2012 | 06:33 AM
Quote: 1LE brake kit in working order? also do you have the emergency brake cable too or did you keep that on the car?
thanks, Tim
The kit came off of a working car this last weekend. I never drove it myself, i purchased an entire rear end from a member here. There are no leaks and all of the slide pins move freely. I did not get the emergency brake cables with the rear, so none are included.
Pics will be up within an hour or so
Reply 0
Feb 2, 2012 | 07:07 AM
will post pics of the rear and x-member later if theres any interest! I will also part out the rear!
Reply 0
Feb 3, 2012 | 04:59 AM
TTT offers welcome!
Reply 0
Feb 3, 2012 | 10:48 AM
Are the PBRs off a 10 or 9 bolt. What would you want for the 9 bolt carrier and ring/pinion shipped in US?
Reply 0
Feb 3, 2012 | 10:57 AM
The pbr's are off of a 10 bolt. The carrier and r/p i would do $60 plus shipping
Reply 0
Feb 3, 2012 | 12:09 PM
What would shipping for carrier and r/p be to 95472? What diam are the rotors and condition? Don't know if I can afford the PBRs but what they cost to ship to same zip. Maybe a package deal?
Reply 0
Feb 3, 2012 | 12:16 PM
Quote: What would shipping for carrier and r/p be to 95472? What diam are the rotors and condition? Don't know if I can afford the PBRs but what they cost to ship to same zip. Maybe a package deal?
Id estimate around 50 for each package to ship due o the weight. Ill have to get you the diameter. But shoul be stock type rotors for a 92 10 bolt. They dont look warped.
Reply 0
Feb 3, 2012 | 03:18 PM
How much for the 1LE's?
Reply 0
Feb 3, 2012 | 03:42 PM
Quote: How much for the 1LE's?
300 plus shipping with the rotors
Reply 0
Feb 3, 2012 | 10:27 PM
the "basic t-56 crossmember" is for thirdgens right? if it is i would be interested in buying it.
Reply 0
Feb 4, 2012 | 05:56 AM
Quote: the "basic t-56 crossmember" is for thirdgens right? if it is i would be interested in buying it.
Yessir, it is for thirdgens and it's all yours if you want it. Shoot me a pm if definetiely interested.
Reply 0
Feb 4, 2012 | 05:44 PM
Re: 1LE Rear brakes, BW 9 Bolt FS 3:23 posi
Xmember sold. Still want to sell the brakes and rear. Offers welcome
Reply 0
Feb 5, 2012 | 10:47 AM
Quote: The pbr's are off of a 10 bolt. The carrier and r/p i would do $60 plus shipping.What would shipping for carrier and r/p be to 95472?
PM sent.
Reply 0
Feb 6, 2012 | 08:45 PM
Re: BW 9 bolt PARTS, Z28 PHB RLCA's
TTT few things sold, put up a few more parts. offers always open
Reply 0
Feb 7, 2012 | 05:25 PM
Bump for today
Reply 0
Feb 8, 2012 | 10:15 AM
Re: stock Z28 Panhard Bar, LCA's, BW 9 bolts parts
Ttt offers
Reply 0
Feb 12, 2012 | 01:25 PM
Re: Mufflex muffler & tail pipes, stock Z28 Panhard Bar, LCA's, BW 9 bolts parts
bump! added my mufflex muffler
Reply 0
Feb 15, 2012 | 04:59 PM
bump?
Reply 0
Feb 21, 2012 | 09:05 AM
Ttt will take any offers
Reply 0
Feb 21, 2012 | 02:09 PM
where in ct are you located?
Reply 0
Feb 21, 2012 | 02:13 PM
Ashford CT. About 10 miles from mass on I84
Reply 0
Subscribe
