[Sold] LT1 Swap part out
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
LT1 Swap part out
Parting out my LT1 swap. Engine is sold. Most is too big to ship.
SLP 1.75" Ceramic coated headers, 3" y-pipe and high flow cat for 82-92 F-body $475 --SOLD
T56 6-speed manual transmission from '95 Trans Am $1500 --SOLD
B&M Ripper shifter for '95 Trans Am $85 --SOLD
Spohn T56 conversion trans cross member w/safety loop and adjustable torque arm for 82-92 F-body $225 --SOLD
LT1 T56 engine harness, PCM, MAF, relay box, VATS, fuel pump relay modified for 82-92 F-body $175
LT1 Radiator, condensor, dual fans, adapter bracket modified for 82-92 F-Body $150
LT1 front accessories including new Alternator and mounting brackets $125
LT1 power steering adapter braided stainless lines for 82-92 F-Body --SOLD
Re: LT1 Swap part out
More pictures
Power Steering Lines
Reservoir, -6 AN Aeroquip high pressure and steel fittings, low pressure side -8 AN hose and aluminum fittings, 16mm O-ring adapter fitings.
Thanks for the offer SUBROC.
Headers still available.
Trans, Spohn cross member and shifter are sold.
Car: 1990 Camaro RS
Engine: 305 L03
Transmission: 700R-4
Axle/Gears: 2.73 Posi
will you sell just the y pipe? i really dont even want the cat im just interested in the y pipe.
No, I want to keep it together.
Getting shipping quote tomorrow on headers. Close-ups of blemish areas including where some wire conduit melted on them.
Edit: Shipping was outrageous, $155 to CT
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
do you have the opti, timing cover, and pig tail left over form the engine? I would aslo be interested in the conversion power steering lines.
Opti and timing cover went with engine. I do have the opti jumper, but it is the one connector with a busted tab.
Power steering lines are available.
OPTI jumper --SOLD
Lowered header price
Headers and Y-pipe sold
1992 Trans Am
Aug 8, 2015 08:16 PM
