[MA] TPIS 10 bolt 78.5" Rear End Girdle for Camaro/Firebird $40
Old May 26, 2012 | 11:00 AM
SargeantSarkasm's Avatar
Car: 1989 Pontiac Trans Am
Engine: 350 TPI L98
Axle/Gears: The ones with the teeth.
TPIS Aluminum 10 bolt Rear End Girdle for Camaro/Firebird. TA Performance is the actual manufacturer, sold with the TPIS logo on it.
Fitment: Chevy 7.5" 10 Bolt Rear End Girdle fits all '82-'02 Camaro & Firebirds, '77 and up S-10/S-15 Trucks, and most '77 and up GM RWD including Monte Carlo equipped with 7.5" or 7.625" Ring gear, 10 Bolt Covers. Fits '94 and up F-body as well.
Mistakenly bought this years ago for my third generation but it wouldn't fit because I had a 9 bolt. Never used!
Comes with all bolts and gasket. This girdle is designed to put a very light pressure on the bearing caps to prevent their deflection under severe load.
$40 plus shipping. Normally sells for over $150.
http://www.taperformance.com/products.asp?cat=48
Mine is the equivalent of TA_1809
From their website:
Specifically designed to add support to the bearing caps under severe loads and acceleration, these girdles substantially strengthen the rear end. They also add fluid capacity, which helps to lower the fluid temperature. Comes with drain and fill plugs for easy maintenance.
All TA Girdles are made of 356 aircraft grade aluminum, heat treated to T6 specifications, each cover is then stress relieved.
All Girdles incorporate a Fill Port and a Drain Port for ease of servicing.
All Girdles incorporate 2 load bolts with swivel "feet" for supporting the bearing caps.
All Girdles increase fluid capacity approx. 1/2 pint.
All Girdles show a decrease in operating temperature, average of 15 degrees.
Weighs about 7.5 lbs.
Improves Undercarriage Appearance.
Attached Thumbnails TPIS 10 bolt 78.5" Rear End Girdle for Camaro/Firebird -2011-01-22-11.34.21.jpg   TPIS 10 bolt 78.5" Rear End Girdle for Camaro/Firebird -2011-01-22-11.34.50.jpg
Old May 26, 2012 | 12:13 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: TPIS 10 bolt 78.5" Rear End Girdle for Camaro/Firebird $40
I will take it. PM sent.
Old May 26, 2012 | 12:22 PM
blackjack12982's Avatar
If he backs out, I've got money ready...
Old May 26, 2012 | 02:56 PM
stealthram92z's Avatar
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
I'm third!!!!
Old May 26, 2012 | 03:28 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
HOLY CRAZY DEAL BATMAN! I'd jump in 4th but already have one.
Old May 28, 2012 | 09:00 PM
lawdog49's Avatar
Car: 91 Z28
well add me to the list if something unusual happens and you still need to sell it!!
Old May 30, 2012 | 07:31 PM
Engine: 350 TPI L98
I had no idea how much interest this would generate. Now I know what it feels like to be a cheap hooker.
The sale is currently pending with the first guy. If it falls through I'll work my way down the list. If I don't repost then you can assume it's been sold. Thanks for your time guys.
Old May 31, 2012 | 01:27 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
$$$ sent
Old Jun 8, 2012 | 05:51 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
