[MD] hard line heater hose without bypass valve
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Looking for hard line heater hose without bypass valve like this:
Car: 92 Camaro RS
Engine: 355 L98 Carb
Transmission: WC T5
Axle/Gears: 3.73 Auburn Posi
Re: Lower Shift Boot & hard line heater hose without bypass valve
I have the hard line heater hose from my 92 RS available if you are still looking. If I see correctly in the picture you posted, it will have 3 outlets on the tube... I can send you a picture of mine if you need.. would 25 shipped work? send me a PM here.
Engine: 5.7, 5.0
No, it should only have an inlet & outlet, the other piece is a mounting tab. What I have now has the 2 outlets, one is for the heater bypass which I want to eliminate. If you could post a pic of what u have, that would be great. Thx.
Car: 92 Camaro RS
Transmission: WC T5
Pictures are sent... I think that I have the tube that you already have.. take a look at the pics and let me know.. thanks, Edward
Engine: 5.7, 5.0
Still searching....
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Got a lower shift boot brand new condition 50shipped
Engine: 5.7, 5.0
Re: hard line heater hose without bypass valve
Already got a shift boot, still looking for the heater line.
Car: 90 TRANS AM
Engine: 305 TpI
Axle/Gears: 3.73 bw
i believe the one i have has 3 outlets on it also but ill check for u tomorrow
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I think I might have the heaterline you are looking for I just have to find the 2 I have here somewhere
Engine: 5.7, 5.0
Cool, how much?
Car: 89 IROC
im gonna have to look tomorrow night at my shop as I know I have to of them and i just dont have them here at my home. I will get back to you for sure
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
I may have this ill have to look
Car: 89 IROC
Sorry I thought I had the one you wanted but I have 2 with the top inlet unfortunately that you didn't want
Engine: 5.7, 5.0
No problem, thanks for looking guys. I capped it off for now but if someone does come across one, I may still take it just b/c it's a cleaner looker than a capped off pipe...
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
$30 + shipping.
It's going back on my 85Z before the weekend if you're not interested. Here's a pic before I pulled it off a couple weeks ago. ( It's been blasted / re-painted flat black and looks V-Good now. )
Post your ZIP code if you need a shipping quote.
Engine: 5.7, 5.0
21074
USPS Priority Mail / insured = $11
USPS Parcel Post / Insured = $10
Send me a PM for details (very soon) if your interested.
Engine: 5.7, 5.0
I'll take it, PM just sent. Thx.
ok i see u found one cus the one i removed from my 88 ta had 3 tubes on it
Engine: 5.7, 5.0
Thanx !!
It was a nice piece and I was a bit sad to see it go - but I'm glad it found a quality car to get used in !
1992 Trans Am
May 10, 2023 07:19 PM
