[IL] Expired (28 Feb 13)
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Expired (28 Feb 13)
Most of this stuff is gone and I forgot to delete this. Sorry for any confusion this caused. (28 Feb 13)
Too nice to sh_itcan but I need it out of my way!
Paypal only, please.
Factory Alt. bracket $5 SOLD!!!
Blank T/B top plate $10
Stock dipstick $5 SOLD!!!
Stock, (non-adj.), FPR cover $5
Functioning EGR Solenoid and tubing $10 SOLD!!!
Jensen 1.5 DIN CD Receiver, BNIB, all there except for mounting sleeve/brackets $50 SOLD!!!
Factory A/C bracket $5 SOLD!!!
3 holed, baffled, perimeter chrome valve covers with oil cap, BNIB $25
BNIB center bolt to perimeter valve cover adapters w/all hdw. $50 SOLD!!!
Used 22lb Bosch III injectors, rattle canned black, set of 8 $50
Partly installed but never "used" ARP header bolts, 3/8,12 pt. These will NOT work w/Dyno Don headers
$10 SOLD!!!
14mm lug/lock set w/2 keys $25
Mechanical temp/oil press/amp gauge w/mtg panel $10
Chrome perimeter valve cover spreader bars $10
Trickflow push rod plates, 3/8 stud, BN, no packaging $10
Used IAC for TPI, functions correctly $20 No longer for sale
Used but mint Hurst Dualgate shifter, all parts included along w/install instructions. Both style boxes can be included if desired. $450 SOLD!!!
Very lightly used Gates serp. belt for underdrive pulley $10
2 very lightly used 180 'stats $3 each or 2 for $5
Very lightly used rad. cap, 7psi $5
Sparkplug wire separators, BNIB $5
BNIB Accel fuel line adapters, (5/16 and 3/8 Saginaw o-ring to 6AN) $12 each, both for $20
Fiberglass Non-A/C blower housing w/resistor,motor, squirrel cage, hose $75- SOLD!!!
BNIB CAI for SD TPI Firebirds, K&N filter $50 SOLD!!!
BNIB base for coolant filter $20
BNIB filter for above base $10
Very Lightly used Hypertech fan switch for 180 'stats $20
Used Dakota Digital SGC 5-C speedo interface $50 SOLD!!!
Used 700R4 speed sensor, (black), and driven gear, was stock w/2.73's $50
AXXB memcal w/appropriate Hypertech chip $50 SOLD!!!
$10 SOLD!!!14mm lug/lock set w/2 keys $25
Car: 92 T/A 'vert
Re: Build leftovers/Garage sale
But wait! There's more!!!
Stock 700R4 pan with drain plug installed. Does NOT leak. $20
Car: 92 T/A 'vert
Re: Build leftovers/Garage sale (Dualgate, A/C delete, Dakota Digital)
Bump
Car: 91 Z28
I'll take the 3 gauge panel- shoot me a pm with what ya gotta have total for it to 35244. should be pretty cheap in a flat rate box. please pm me a few more, better pics of it please- what brand? installed or still new? thanks.
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
marked
Car: 92 T/A 'vert
PLMK Thread Starter
Car: 92 T/A 'vert
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Used Dakota Digital SGC 5-C speedo interface to 23456
Car: 92 T/A 'vert
Car: 92 T/A 'vert
Car: 92 T/A 'vert
Car: 92 T/A 'vert
Car: 92 T/A 'vert
Car: 91 Z28
amps instead of volts, sorry i missed that and just noticed it in the other pics. i need one with a volts gauge, i'll pass. glws.
Car: 92 T/A 'vert
Car: 92 T/A 'vert
All pm's replied to.
Car: 92 T/A 'vert
Bump
Car: 92 T/A 'vert
Replied.
Car: 92 Camaro RS
Engine: 355 L98 Carb
Transmission: WC T5
Axle/Gears: 3.73 Auburn Posi
Sent you a PM on the oil dipstick and tube.. Thanks, Edward
Car: 92 T/A 'vert
All PM's replied. Dualgate sold.
Car: 92 T/A 'vert
A few more items sold.
Car: 92 T/A 'vert
Make offer.
Car: 92 T/A 'vert
Car: 92 Camaro RS
Transmission: WC T5
Got my package today! Positive feedback left for you! Thanks again!!
Car: 1990 GTA
Axle/Gears: 3.90
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
Free Bump.
Looks like someone got a mighty nice looking AC Delete Fiberglass box for cheap! It's 1 in 3 or 1 in 4 ever made currently out of that mold.
Lots of good stuff left.
Car: 92 T/A 'vert
So, THAT'S where I dropped it!
Car: 92 T/A 'vert
Re: Build leftovers/Garage sale (TRY A LOWBALL OFFER!)
ttt
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
just a quick question : the Dakota Digital SGC 5-C speedo interface. what does it do for used for?
Car: 92 T/A 'vert
http://www.dakotadigital.com/index.c...rod/prd126.htm
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
So that would be something needed if I was trying to install a t56 ?
Car: 92 T/A 'vert
Yes, many use these in that swap.
Car: 92 T/A 'vert
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
dang I should of had you send me the egr solenoid ;(
Engine: Lb9
Transmission: M20
$5.20 for just the egr solenoid ?
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
money sent for the the Dakota Digital SGC 5-C speedo interface.
Car: 92 T/A 'vert
ebay
Engine: Lb9
Transmission: M20
Car: 92 T/A 'vert
Re: Build leftovers/Garage sale (HOLIDAY SALE! 25% OFF!!!)
Big Sale!
Car: 92 T/A 'vert
Re: Build leftovers/Garage sale (Forget about it! FREE!!! Just pay shipping)
Bump! Take my stuff, please!
