[Sold] Tuned port injection reprograming
Old Apr 12, 2013 | 07:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Size:  100.2 KB[/QUOTE]
Reprogram of stock axxb, tuned port 90-92 speed density, to axyc 305 manual transmission, removed vats, fans on 190f off 170f , emission functions and errors. Soldered in a dip socket and installed a sst27sf512. $65 for reprograming and $7 for dip and sst eeprom.
This ad is for a member of tgo
Old Apr 12, 2013 | 07:52 PM
TFS355S10's Avatar
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
Re: Tuned port injection reprograming
Thanks Brian. I hope the rest of my build goes as smoothly as this part has. I'm sure I'll bombard you with more questions... LOL
Old Apr 12, 2013 | 09:27 PM
Engine: Lb9
Transmission: M20
Bring the questions on, sounds like your pretty close to firing it up
Old Apr 13, 2013 | 09:41 AM
TFS355S10's Avatar
I sure hope so... LOL
If this motor runs as many miles as I've put on my creeper under it I should be good for years! LOL
Old Apr 13, 2013 | 09:32 PM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
Can you burn a chip for a cam swap and cat delete?
Old Apr 13, 2013 | 11:02 PM
Engine: Lb9
Transmission: M20
On the cam swap I can modify your memcal with a flash eeprom to make it easier for you to tune. But even with a datalog live tuning is the best and fastest way do correct the air fuel ratio.
Old Apr 17, 2013 | 11:01 AM
jmb714's Avatar
Want a title? Post!
Car: 87 IROC
Transmission: 6 Speed
Can you re program any chip or just camaro to fit in a camaro
Old Apr 17, 2013 | 11:48 AM
TFS355S10's Avatar
Mine's for a Trans Am TPI 305 in a Sonoma pickup..... LOL
I'm sure he can do all TPI chips, dunno about others though.
What about TBI chips, can ya do those too Brian?
Someday I'll have to build a motor for my old 93 (TBI C1500 w/454k miles and some change. On it's second motor though... LOL)
I've been collecting parts for it also. It'll be a 383, vortec heads, 4 barrel style aluminum intake of some kind to fit the vortec heads, 454 throttle body w adapter plate, shorty or mid length headers, and as of now unknown cam. (Somethin mild to keep the vacuum signal up, but gain some performance)
I've never seen the ecm in it LOL so dunno what the number of it is.
Old Apr 17, 2013 | 12:21 PM
Engine: Lb9
Transmission: M20
Send me a message and let me know what you have as far as engine and transmission and I will see what I can do for you
Old Apr 17, 2013 | 12:26 PM
Engine: Lb9
Transmission: M20
When the time comes let me know I will be glad to help, I do dabble with tbi. You should buy a moates.net burn 2 so I can assist you better bye looking at datalogs and just change a file and send to you. It maybe be a 427 ecm its behind the glove box insert.
Old Apr 17, 2013 | 01:25 PM
jmb714's Avatar
Want a title? Post!
Car: 87 IROC
Two are olds v 6 1 i do believe is a cadillac
Old Apr 17, 2013 | 02:34 PM
Engine: Lb9
Transmission: M20
What are the letters on the top of the v6 ones ? I might be able to make them work for the tpi maf 1227165 ecm.
Old Apr 17, 2013 | 04:17 PM
jmb714's Avatar
Want a title? Post!
Car: 87 IROC
v6 alca bdhr - cad. bcdb
Old Apr 17, 2013 | 04:22 PM
Engine: Lb9
Transmission: M20
I wouldn't be able to get those 3.3l or 4.9l chips to work. I do have real tpi v8 memcals or I can convert a 3.1l memcal I have to work with the tpi maf for $50 shipped
Old Jun 12, 2013 | 08:25 AM
Engine: Lb9
Transmission: M20
Ttt
racereese
Oct 10, 2015 09:39 PM
customblackbird
Oct 1, 2015 04:30 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
m00n420
Sep 11, 2015 02:39 PM
