[WI] cam and rockers
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
cam and rockers
I am going to Korea very soon and I need to get rid of some parts that I will no longer need. Some of them are from previously conceived plans that were changed. I will be adding more parts as I think of them. I am currently in Fayetteville, NC if you are close enough to pick up parts. All prices are OBO and plus shipping.
$250 GM Performance cam pn 19244485
duration 234/242
lift .539/.558
seperation 112*
Hydraulic roller
only installed never ran
$40 94 LT1 harmonic balancer with hub piece
$50 TBI throttle body, includes TPS IAC 18 PSI spring and new diaphragm
$60 TPI over the radiator intake with filters included
$60 stripped LT1 intake manifold
$100 86 305 short block
Crank shaft in excelent condition, cyliinders have been only honed once, no ridge at all, had about 80k
I don't want to throw this one out if possible
Added:
$225 TPI intake setup; base, runners, plenum, injectors and rails, coil, throttle bracket, various sensors/solenoids
$120 WC T-5 rebuild kit; bearings and synchros it is for a for so the seals may not match
Sold Speed Pro 350 pistons
Sold L98 aluminum 113 heads, not ported, guide plates installed
Sold 94 LT1 optispark with timing cover and harness piece. I never tested it
Sold comp cams roller rockers
I'll be adding parts as I find them
duration 234/242
lift .539/.558
seperation 112*
Hydraulic roller
Added:
Car: 86 Camaro Z28
Re: cam and rockers
PM me an offer I can't go too much lower. This money is going towards getting the stuff to do a timing belt on my wifes car before she drives it home to Wisconsin
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: cam and rockers
PM sent.
Does the intake with filters include the connection to the TB? Thx.
Car: 86 Camaro Z28
Re: cam and rockers
some pics of the heads. I'll get more when I get to my garage this afternoon. replied to PMs
Car: 86 Camaro Z28
Re: cam and rockers
Heads sold, added rear diff and pistons
I'm getting too close to crunch time. I am also willing to trade for tubular rear suspension, jegster tunnel mount torque arm, and LS1 conversion brackets.
Car: 86 Camaro Z28
Re: cam and rockers
Evening bump. I will separate the aluminum drums if someone is interested.
Car: 86 Camaro Z28
Re: cam and rockers
Bump for last full day in North Carolina. Starting next week I'll be in south eastern Wisconsin
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Re: cam and rockers
Hi there,
Is that a 350 throttle body, or 305? does it have 350 injecters? 62# or 68#?
Car: 86 Camaro Z28
Re: cam and rockers
it is off a 350 I'm not sure which injectors are in it. Is there a way to tell without taking it apart? It worked great when I was using it in my truck.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: cam and rockers
The numbers on top of the injectors will identify the part number google that to find the #hr more than likely 55#hr they will have a orange covering were the injector plug connects.
Car: 86 Camaro Z28
Re: cam and rockers
Thanks tuned, they're 55# like you said. The number on top is GM5235206*rpd
Car: 86 Camaro Z28
Re: cam and rockers
http://tbichips.com/truckmods.htm
Car: 86 Camaro Z28
Re: cam and rockers
Bump pistons sold
Car: 86 Camaro Z28
Re: cam and rockers
added TPI intake, I forgot to add that it is from an 89 Formula 350 and has the TB as well. The distributor bolt was also broken off when it was taken apart
added WC T-5 rebuild kit
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
