Suspension parts Sphon/Hotchkis/BMR/Global West
Old May 18, 2013 | 08:20 PM
MarkF's Avatar
N
Old May 18, 2013 | 08:22 PM
MarkF's Avatar
Re: Suspension parts Sphon/Hotchkis/BMR/Global West
H
Old May 19, 2013 | 12:37 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Originally Posted by MarkF
Name your price!! Please make it worthwhile for me to pack up the heavier stuff and ship. Or local pickup would be great.
* Sphon torque .... This setup is for a retro fit T-56 setup(uses T-5 bell housing) for other applications you'll need to modify the tranny mount positioning.
I'm not familiar with this, can you post a link for more info or anything? The T56 using a T5 bell
Old May 19, 2013 | 01:30 PM
MarkF's Avatar
https://www.thirdgen.org/forums/tran...rofit-t56.html
sorry can't find any great links, back in the day it was widely covered by all the rags but here's a quick description for you:
the retrofit T56 was never very popular since you had to buy the box new from tremec vs junk yard 4th gen conversion. Tremec made a box that had a different length input shaft and came with an adapter plate designed to mate with the T5 bellhousing (17 deg tilt) or older 4 speed GM cars. It also had a different tail housing that relocated shifter to stock location and a mechanical speedo output. The torque arm and DS needed to get shortened by about 2" and a modified/custom x-member was needed. It's probably a hard box to find and has no OEM application. The big T56 shops can make these types of boxes on request all the time I'm sure and you can probably find the individual parts needed to build one. Internal gear ratios are:
2.97:1, 2.07:1, 1.43:1, 1.00:1, 0.80:1, 0.62:1 3.28:1 reverse
Old May 19, 2013 | 02:23 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
How many miles on the lower control arm bushings? Are the ball joints any good?
Old May 19, 2013 | 02:53 PM
MarkF's Avatar
Hard to say exact millage, I didn't make a clear note in my log. My best guess is they were installed on the car from 2000 to 2008. No slop in ball joints when I took them off. One of the boots has a tear.
Old May 19, 2013 | 04:04 PM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
That torque arm- is it an older design? All the arms from Spohn nowadays have a fixed front attachment on a shackle...this doesn't look like it uses a shackle? The crossmember could modify for my application no prob but am curious about that design of TQ arm?
Old May 19, 2013 | 06:14 PM
MarkF's Avatar
T
Old May 19, 2013 | 08:51 PM
86purpledragon's Avatar
Car: 1986 Trans Am
How much for either panhard bar plus shipping to 68123?
Old May 19, 2013 | 08:56 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
What are you looking to get out of the cross member? I already have a spohn cross member, but back when I did the T5 bell-t56 swap there was no x member that would fit it so I had to hack up the standard t56 cross member.
Old May 19, 2013 | 11:12 PM
MarkF's Avatar
How about $20 for panhard? shipping to 68123 is $18
92RS, I'm a bit hesitant to break up the torque arm and crossmember since they're suppose to work together. But looks like somebody else is interested in the torque arm alone so maybe breaking it up can work out. Just waiting to hear back from them.
Old May 27, 2013 | 08:18 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Pics and price of a-arms please. I already have new moog balljoints in mine just need bushings really. let me know.
thanks
Old May 28, 2013 | 10:23 AM
MarkF's Avatar
Pics
Attached Thumbnails Suspension parts Sphon/Hotchkis/BMR/Global West-img_2182.jpg   Suspension parts Sphon/Hotchkis/BMR/Global West-img_2183.jpg   Suspension parts Sphon/Hotchkis/BMR/Global West-img_2184.jpg
Old May 28, 2013 | 10:30 AM
MarkF's Avatar
How's $45+shipping? swapping out old stock bushings is no walk in the park, I think it would be easier to just take the entire a-arm and put in new ball joints. The ball joints on these were ok when I took them off, no slop, but can't remember how much use is on them. Replacing them could be good preventative. One of them has a tear in the boot that I tried to take a pic of.
Attached Thumbnails Suspension parts Sphon/Hotchkis/BMR/Global West-img_2186.jpg   Suspension parts Sphon/Hotchkis/BMR/Global West-img_2187.jpg
Old May 28, 2013 | 01:44 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
how much for the panhard bars?
Old May 28, 2013 | 07:11 PM
MarkF's Avatar
How about $20 + shipping for PHR?
Old May 28, 2013 | 11:20 PM
jersyboyy's Avatar
Car: 85 Camaro
I wish I was still in nj id save on shipping! But im still interested as I could with not too much effort swap my new ball joints from my current arms to these.
also is that electric tape wrapped around the bushings?
Old May 29, 2013 | 09:17 AM
MarkF's Avatar
It's duct tape holding the derlin washers in place. Here's a diagram of the bushings.
Attached Thumbnails Suspension parts Sphon/Hotchkis/BMR/Global West-instructions.jpg
Old May 29, 2013 | 11:58 AM
jersyboyy's Avatar
Car: 85 Camaro
pm me best shipped price to 71105
end paypal info
Old Jun 2, 2013 | 10:21 PM
jersyboyy's Avatar
Car: 85 Camaro
awaiting paypal information
Old Jul 11, 2013 | 11:32 PM
jedrom's Avatar
Car: 1989 IROC-Z
Engine: 350 Jasper
Still have the hotchkis panhard? And any idea how much you'd charge for it with shipping to 13027? Thanks
Old Jul 14, 2013 | 12:59 AM
MarkF's Avatar
Both panhards still available. USPS is giving me $14 shipping to 13027
By the way I also have a Hellwig solid 33mm front sway bar if anybody is interested. That is as stiff as you can go.
Old Jul 14, 2013 | 08:22 AM
jedrom's Avatar
Car: 1989 IROC-Z
Engine: 350 Jasper
How much for the Hotchkis?
Old Jul 14, 2013 | 08:59 AM
MarkF's Avatar
How about $20?
Old Jul 14, 2013 | 09:06 AM
jedrom's Avatar
Car: 1989 IROC-Z
Engine: 350 Jasper
That sounds good Mark, I'm sending you a PM now
Old Jul 18, 2013 | 12:25 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Still have the control arms? Price shipped to 60465?
Old Jul 19, 2013 | 07:23 PM
MarkF's Avatar
Hotchkis is sold. BMR bar still available shipping to 60465 is $15
Old Aug 4, 2013 | 08:36 PM
DrNBody's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: LB9 305 TPI
How much can you do for the BMR panhard bar shipped to 11354?
Old Aug 4, 2013 | 11:45 PM
MarkF's Avatar
Longisland! Crap we could probably meetup in Manhattan and save shipping. I shipped the hotchkiss panhard to upstate NY for about $13 so no more than that. The bar itself is $20
Old Aug 5, 2013 | 08:47 PM
DrNBody's Avatar
Engine: LB9 305 TPI
Really? Hmm, how do the BMR bars compare to UMI?
Old Aug 6, 2013 | 12:40 AM
MarkF's Avatar
No personal experience with UMI but I took a look at their website and the part# 2020 is the closest thing to the BMR I'm selling except mine doesn't have grease fittings.
http://umiperformance.com/catalog/in...68rivc20i55tq5
Old Aug 6, 2013 | 08:34 AM
DrNBody's Avatar
Engine: LB9 305 TPI
Ahh it's non adjustable? Hmm. Let me think about it.
If I were to get it when would we meet up?
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
