[CO] Tpi , Tbi reprograming and memcals/proms
Old Jul 6, 2013 | 02:22 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Doing a engine swap, want a updated tune ? Send me a personal message
Old Jul 9, 2013 | 03:50 AM
91rs1022's Avatar
Car: 89 Camaro RS
Transmission: 5 Speed
Re: Tpi , Tbi reprograming and memcals/proms
Does great work and very fast service!!!
Old Jul 9, 2013 | 05:18 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
really great guy..would highly recommend doing business with him....props to ya bro
Old Jul 10, 2013 | 12:36 PM
Engine: Lb9
Transmission: M20
Old Jul 10, 2013 | 06:05 PM
hardcoreZcar's Avatar
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
I have a 350 tbi, stock minus smog, was wondering if there is much power to be had in a performance tune for my application?
Old Jul 10, 2013 | 06:15 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Suppose I had switched my tpi stuff over to a miniram or a stealth ram and wanted to run a 4th gen pcm can you program it? And if so how much?
Old Jul 10, 2013 | 06:53 PM
Engine: Lb9
Transmission: M20
If you have a 122746 ecm all I can provide is a mostly is a mostly stock tune.
If you want more than that live tuning needs to be done after you datalog.
Old Jul 10, 2013 | 06:55 PM
Engine: Lb9
Transmission: M20
For The 4th gen camaro ecms, I can only reprogram the 16159278 with the removable memcal.
Old Jul 15, 2013 | 07:15 PM
Engine: Lb9
Transmission: M20
Bump
Old Jul 18, 2013 | 04:17 PM
DancesWithDeath's Avatar
Car: 1991 rs camaro
Amazing... Took me all of 15 minutes to do. My car hasn't ran in 2 months. Now it purring
Like a lion. Brian even let me call him to figure out how to do the relay part. 10/10
Old Jul 18, 2013 | 08:50 PM
wicked92RS's Avatar
Car: 1992 CAMARO RS
Engine: V8 305 TBI
Transmission: 700R4 at
Axle/Gears: non-posi not sure what gears
Doin a 5 speed swap would I need to reprogram my ecm? If so how much?
Old Jul 18, 2013 | 09:06 PM
Engine: Lb9
Transmission: M20
It is not totally necessary to have a prom reprogramed if you are going from a automatic to a manual transmission. The idle air control is slightly different between the two different tunes so if you experience bucking on deceleration you would want a new prom.The idle target speed is also different between a automatic and manual transmission. For tbi proms in there holder I charge $55 shipped.
Old Jul 19, 2013 | 11:45 AM
wicked92RS's Avatar
Car: 1992 CAMARO RS
Engine: V8 305 TBI
So id have to send u the who ecu
Old Jul 19, 2013 | 12:20 PM
Engine: Lb9
Transmission: M20
I would just send you the prom, it is removable from the ecm. Would be a plug and go play.
Old Jul 19, 2013 | 04:50 PM
wicked92RS's Avatar
Car: 1992 CAMARO RS
Engine: V8 305 TBI
Ok so wen im ready ill send u a message thanks
Old Jul 19, 2013 | 08:56 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I am doing a 5 speed swap on my 91 Z/28 350. Can I send mine to you so you can put in a prom and make sure its good to go. I bought the thing used because my car didn't have an ecm in it.
Old Jul 19, 2013 | 09:29 PM
Engine: Lb9
Transmission: M20
Sending you a pm
Old Jul 22, 2013 | 07:28 AM
Engine: Lb9
Transmission: M20
rubber baby buggy bumpers
Old Jul 24, 2013 | 05:47 AM
Engine: Lb9
Transmission: M20
Front page news
Old Jul 28, 2013 | 12:53 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/dfi-...rformance.html
Old Aug 3, 2013 | 10:43 PM
Engine: Lb9
Transmission: M20
Ttt
Old Aug 6, 2013 | 03:06 PM
Engine: Lb9
Transmission: M20
vats removal only in the states tpi, 3.1L $30 includes priority shipping to return your memcal chip
Old Aug 6, 2013 | 04:38 PM
art91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 350 5.7 liter
Great guy to do business with, very knowledgable
Old Aug 6, 2013 | 05:07 PM
Engine: Lb9
Transmission: M20
Thank you Art
Old Aug 9, 2013 | 09:11 AM
Engine: Lb9
Transmission: M20
To The Top
Old Aug 12, 2013 | 12:55 AM
Engine: Lb9
Transmission: M20
Bump
Old Aug 18, 2013 | 01:03 AM
Engine: Lb9
Transmission: M20
Bump
Old Aug 21, 2013 | 10:59 AM
Engine: Lb9
Transmission: M20
Ttt
Old Aug 29, 2013 | 01:32 AM
Engine: Lb9
Transmission: M20
To the top
Old Sep 4, 2013 | 12:34 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
tuned perf, I'm doing an engine swap. Already 350 f inj and knock sensor. Next in my agenda is the PROM. Do you re-program the 305 PROM, or, do I have to send you a 350 PROM and you re-program, or, you have PROMs for sale? How does it work? My email is wruiz922@verizon.net if you need to reply offline. Thanks.
Old Sep 4, 2013 | 02:55 PM
Engine: Lb9
Transmission: M20
Wruiz sending you a personal message.
Old Sep 5, 2013 | 09:54 AM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Is there anything worthwhile that you can do for a 305 tbi with stock exhaust manifolds, 3" after the Y pipe, Edelbrock Performer lower intake, and an MSD 6A box? No EGR, AIR blocked off; if it matters.
Old Sep 5, 2013 | 10:13 AM
Engine: Lb9
Transmission: M20
There is not to much that can be done on improvement on a mostly stock engine. The egr code 32 and egr function can be disabled. I can also disable the air diverter function.
Old Sep 5, 2013 | 11:03 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
If I sent you a 1987 Firebird 5.7L ECM #1227165 without a PROM, could you install a PROM and program it as a 1989 ECM with the cold start injector delete?
Old Sep 5, 2013 | 01:46 PM
Engine: Lb9
Transmission: M20
Sending you a pm lonestar7
Old Sep 8, 2013 | 10:02 AM
Midnight85's Avatar
Car: 1985 Corvette
Engine: 383
Axle/Gears: 3:07
I have an Edelbrock Pro Flo XT manifold on my '85 Corvette and Brian nailed the tune on the second try. My car runs like it has never ran before, I have nothing but good to say about him and his work.
Old Sep 12, 2013 | 09:11 AM
Engine: Lb9
Transmission: M20
bumpity bump bump
Old Sep 15, 2013 | 07:01 PM
Engine: Lb9
Transmission: M20
Ttt
Old Sep 19, 2013 | 04:33 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Good and fast sevice.
Old Sep 21, 2013 | 09:28 AM
Engine: Lb9
Transmission: M20
Thank you again for you purchase jari
Old Sep 25, 2013 | 06:42 PM
Engine: Lb9
Transmission: M20
Bump
Old Sep 29, 2013 | 01:40 PM
Engine: Lb9
Transmission: M20
To The Top
Old Oct 1, 2013 | 10:48 AM
Engine: Lb9
Transmission: M20
Up up up
Old Oct 6, 2013 | 12:38 PM
Engine: Lb9
Transmission: M20
Bump
Old Oct 6, 2013 | 12:53 PM
NewKindOfClown's Avatar
Car: '91 Z28 / '93 Jeep Wrangler
Engine: 5.7L L98 / 4.0L I6
Transmission: 700r4 Auto / 32RH Auto
Axle/Gears: Posi 3.23 / Open 3.07
After answering a bunch of my questions, Tuned Performance sent me a PROM with VATS disabled. Product was shipped very quickly, arrived in a couple days, was packaged well, and works perfectly. My car is running for the first time in five months.
I highly recommend this seller.
Old Oct 6, 2013 | 02:37 PM
89irocadam's Avatar
Car: 89 GTA 14 Tundra Crewmax
Engine: 388hsr 5.7 32valve
Transmission: T56 6spd auto
89 GTA 383 HSR gtp injectors lt4 cam vortec heads 5spd
car was an lb9 originally
What can you do for me sir?
adam
Old Oct 6, 2013 | 02:53 PM
Engine: Lb9
Transmission: M20
For your combination, I would start with a base tune and build off of that to correct fueling.
There are a few ways of doing the tuning sending me a datalog and I mail you a replacement eprom or if you purchase a moates.net burn 2 I can solder in a adapter on your memcal so it will accept a newer flash based eeprom. TTS data master or tunerpro Bolth work well of datalogging but the 1227165 ecm is hit or miss on connection.
Old Oct 7, 2013 | 03:15 PM
WoodenRegent's Avatar
Car: 1991 Camaro RS
Engine: 5.8l Aluminum LSX
Axle/Gears: 10 Bolt 3.42 "Spooled"
Thinking about doing a heads, cam, and intake mani swap along with the Ultimate TBI mods and an afpr. already have headers and an open element filter. Car is a 350 Tbi, T5 Manual. What do you suggest?
Old Oct 7, 2013 | 03:37 PM
Engine: Lb9
Transmission: M20
If your 350 is a truck engine or caprice I can work up a custom tune. unless your running a mild camshaft or 305 55#hr injectors there would not be a need to install a afpr. Feel free to send me a pm I have some choices to help you out
Old Oct 7, 2013 | 08:41 PM
Car: 1991 Camaro RS
it runs fine right now. But I WANT to do get a little bigger cam heads and intake. Will I need live tuning?
