[TX] Four SLP 3" intermediate pipes
Sold most of what I had but still have this...
Four SLP 3 inch intermediate pipes new never used. May require some modifications to work with your specific setup. Inlet shrinks down to slide into a true 3 inch pipe. $140 each
THESE HAVE ALL BEEN SOLD GUYS.
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
Re: Dyno Don, Accel Base, Superram, LPE 58mm, UMI, Lloyd Elliott cam, SLP TOTL + I pi
Letting go of my goodies for another project. Prices are listed and shipping is extra.
Dyno Don 1 3/4 inch headers with 2 1/2 inch Y pipe. NIB. $650
Accel Base in great shape. Extra material professionally welded over runners. No material taken out just added if you want to do some big porting. Is grey and looks like powdercoat. EGR block off plates. $325
Accel LPE super ram in nice shape. Not ported and ready to rock. I'm selling this with a brand new set of super ram gaskets. One of if not the best aftermarket intake manifold out there. Pulls extremely hard and will not suffer torque loss like the miniram does. $750
Accel LPE 58mm 89-92 TPI throttle body in excellent shape with all hardware, TPS, and IAC. $275
UMI chassis mounted adjustable torque arm with new rear end housing bolts. For use with 700R4 or T-5. 82-92 F-body. NIB. $350
UMI single adjustable PHR with poly ends. 82-02 F-body. NIB. $80
UMI LCA's. Double adjustable with roto joints. 82-02 F-body. NIB. $235
UMI LCA relocation brackets with all hardware. 82-02 F-body. NIB. $80
Lunati Custom spec'd by Lloyd Elliott. NIB. 231/239 .576/.585 110 LSA $250
I also have 3 SLP two on the left mufflers brand new never used. $250 each
Last thing available is 3 SLP 3 inch intermediate pipes new never used as well. $150 each
Car: '89/'91 firehawk#25-R
Engine: 5.7
Transmission: auto 700r4(gathering 6spd parts
Axle/Gears: dana 44 9-bolt 3.54
pm sent on a grip of items...
Car: 1991 z28 t top
Engine: 406 dead, now 383hsr
Transmission: t5/ saving for tko
Axle/Gears: 373
How much for the lca brackets shipped to 44256
Engine: 5.7
paymeny sent for the UMI chassis mounted adjustable torque arm with new rear end housing bolts. For use with 700R4 or T-5. 82-92 F-body. NIB
funds sent on 7/18/13 @ 21:15hrs.... let me know when you receive... thank you..
Engine: 4++,350 & 305 CIs
Re: Four SLP 3" intermediate pipes
If anyone has one of these intermediate pipes and is not using it, I'd like to buy one or all ???
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
TTOP350 are these pipes stainless? i will have to check my parts shed to see what i got left.
bumpy
bump
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
