[MI] Upper Radiator Mount
Car: 1998 Camaro Z28
Engine: 6.0L
I'm looking for the plastic radiator mount for a V8, I really dont want to drop $100 on one of them online, and dont like the chrome ones. Anyone have a good used OEM one to sell?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Upper Radiator Mount
Are you looking for one with a single or dual fan ? You might want to ask this person and even make them a little lower offer.
http://www.ebay.com/itm/1985-1992-CAMARO-V8-5-0L-305-RADIATOR-FAN-UPPER-PANEL-SHROUD-/200949110708?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec98017b4&vxp=mtr
Engine: 6.0L
It would be for a single fan. There shouldn't be any difference between the V6 fan and V8 fan, is there? I plan to keep the V6 fan and I thought I read somewhere it can be used, so mounting shouldnt be an issue.
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
A v6 and v8 are different. The only difference is that the rad hose cradle is on opposite sides. Otherwise they bolt up the same.
Engine: 6.0L
I know theyre different, I found that out when i went to put the V6 one on lol. What I meant by different was does the V6 fan bolt up to a V8 mount, or will I need a V8 fan.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You're 'Good-to-Go',........The electric fans are exactly the same !
P.S. I've got an upper V8 Shroud,... $35 + shipping. Post your ZIP code if you need a shipping quote.
Car: 86 IROC
Axle/Gears: BW 3.27
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I Have a v8 one 50.00 shipped
http://www.brucesthirdgenparts.com/s...o-Upper/Detail
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
