parting out 1986 iroc z28 tpi
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Car: 1998 Camaro Z28
Engine: 6.0L
Re: parting out 1986 iroc z28 tpi
Looks like a 145mph speedo, do all gauges work? If so, how much shipped to 48329?
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Did you get my pm on radio and shift ****?
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
If timmy doesnt take the radio id be interested in it
Car: 1984 Camaro Berlinetta
Axle/Gears: Australian 9 bolt 3.27 posi
I'm interested in the horn button. Can you post a clear close up of it?How much shipped to me in Canada? My postal code is P0T2J0
thanks.
thanks.
ok,are pm functions not working here? Lets try this...
interested in the round shifter **** and the factory radio if it is good and everything works..price shipped on those to 34475 please
The **** is broken and the car is dead...battery...havent had a chance to jump it and check radio or other parts
Car: '89 trans am gta
Engine: 5.7 L 350 TPI
Axle/Gears: not a clue!
I need the driver's side arm rest from the door panel (black) if it's in good & straight condition.send me a pm. thanks.
Car: 87 IROC Z
Engine: 5.7
I need the steering wheel assembly. Wheel, horn button, mounting bracket, screws, etc. Everything that connects the wheel to the column.
Steve
Steve
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Hey, I live in Milford MA and am looking to replace my whole dash and center console. How much would it cost, I don't need it shipped. I could even help you get it out of the car, I have pulled my dash out at least a dozen times!
Thanks.
Thanks.
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Engine: LS3
any chance you could post a better pic of the dash, showing all of it?
thanks
thanks
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
I need a tachometer. how much to 71047?
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Steering column, shift **** and push button shipped to 76366?
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
What kind of shape are the door lock escutcheons in? Pictures please?
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
what color is the headliner? and how much shipped to 38251
Door lock escutcheon pictures please?
Car: 86 Iroc
Engine: 420HP/440FT-LB SB355
Axle/Gears: 10 Bolt 3.73
I'm looking for the whole dash, don't need the gauges, or dash pad. How much??
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
does it have the window switch in the center counsule if so how much shipped to 58561. i want both drivers and passenger
Car: 1985 IROC-Z/1987 IROC-Z/1988 IROC-Z
Engine: Four 305 TPI LB9's
Transmission: Two 700R4's/One WC T-5
Axle/Gears: Posi's 3:42/2:73/3:55/2:73
Hello, how much for the entire dash shell? Does it have hairline cracks in the middle, where the center console is? How about the four mount holes? I'll take the shell if your willing to sell it. I just need the shell, no bezels, vents or badges. Please let me know if your willing to ship it. Thanks.
Car: 92 camaro rs
Engine: 305 t.b.i.
Hi,
How much for the shifter/ash tray trim piece around the shifter? Shipped to 18974. If possible may i see a pic of it? No broken pieces or cracks?
Mark
Mark
Want a title? Post!
Car: 89 IROC-Z
Engine: 5.7L
Transmission: AUTO.
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
