Radio bezel for '89 trans am
Car: '89 trans am gta
Engine: 5.7 L 350 TPI
Axle/Gears: not a clue!
i need the radio bezel for my trans am. It's the plastic trim piece that goes around radio and heater controls.
I believe the console was swapped out with an 82-style console, so i think the bezels are different between the 82 and 89.
Re: Radio bezel for '89 trans am
i'm still in need of a radio bezel that will fit my 82-style console. This is the plastic trim piece that goes around the radio and heater controls.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I believe that the '82 console is less common (more like the Camaro) and the shifter plate would be for a three speed vs. the 4 speed with over drive. It also may not bolt up to an '89 dash correctly.
I would suggest posting a clear pic of what you actually have so that you can locate the correct bezel for your needs.
i'm not worried about the shifter plate, i already have one of those.
the older style console will bolt up just fine. I need the radio/heater trim piece.
the console is from an 82. I have a 700r4 tranny (1989) though. The 82 originally had the 3-speed, but now i have the 4-OD tranny. I put the 82 console in my 89 car.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
Pilotrick50
Sep 2, 2015 12:48 PM
