[PA] 1988 Firbird Formula drivetrain parts prices lowered
All parts are off of a 1988 Pontiac Firebird I just recently parted out.
1) 305 short block (rebuilt)w/ approx. 15k miles on it. Motor had 8.39:1 comp w/ 64cc heads. Has mild cam (specs unknown). Stock crank and rods, Mellings oil pump. Asking $250
3) Edelbrock Performer intake manifold for SBC $ 40
6) Pertronix Dist. advance kit $10 (brand new)
7)Edelbrock Carb 600cfm manual choke #1405. works good $60
8) Aluminum pulleys 5 rib w/ v-belt for Power steering $40
9) Vacuum canister $15
10) chromoly push rods $25
11) Stock aluminum radiator ( in excellent shape) $50
Located in Hatboro, Pa
Car: 1988 chevy Camaro Iroc-Z28
Engine: 305 tpi
Axle/Gears: G80 273
Re: 1988 Firbird Formula drivetrain parts
What year is the engine you have for sale?Is it a roller motor,centerbolt style valve covers.I live in effort pa and need a new engine for my Iroc-z.Thanks
It is the original block but it has trick flow heads and an aftermarket cam. Heads are for sale separately. I am selling the short block. I will have a better idea of what crank, rods and pistons are in it when I pull the heads off tomorrow.
Engine: 305 tpi
Axle/Gears: G80 273
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Are you selling, and if so, what would be your price for the following items shipped to 32583:
Motor Mounts
Serpentine Accessory Brackets, PS Pump, Alternator, and A/C Compressor
Steering Box
Thanks!
Motor Mounts
Steering Box
Thanks!
More info on motor:
305 bored .030 over
Speed Pro hypereutectic flat top pistons
8.39:1 comp w/ 64cc chamber heads
Flat tappet cam specs unknown
Motor very clean on inside
Motor ran good no smoke
I should have more info on components used on bottom end tomorrow
305 bored .030 over
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Can you send me a pm, or post your email address
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Driveshaft ?
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
Car: 1991 firebird
Axle/Gears: 4.10
Car: 1991 firebird
Axle/Gears: 4.10
Just a stock vacuum canister ?
91' bird 305 TBI T-5, trick flow heads, 4.10 gears, full UMI setup, track times coming soon!
Re: 1988 Firbird Formula drivetrain parts prices lowered
You are thinking of a xarbon canister. This is foe a car with a big cam so you xan retain your power brake and other vacuum assisted accessories.
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
is that a flowmaster muffler? How much? (if it's not rotted out)
colton_carlson
Mar 8, 2019 12:21 PM
