Comp Full Roller Rockers
Old Jun 30, 2014 | 07:20 PM
school boy's Avatar
http://www.summitracing.com/parts/cca-17002-16
They were installed but removed same day. im needing to go with 1.5 rockers so these need to go.
$125 shipped
I will sell the rockers without the poly locks for $75 if anyone is interested. Im debating on using them with my other rockers.
Old Jul 2, 2014 | 07:44 PM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Re: Comp Full Roller Rockers
if im running a stock valve cover, 1991 305, will it clear or will it hit the inside?
Old Jul 2, 2014 | 08:34 PM
school boy's Avatar
im not sure, I already had tall valve covers but they did clear the center bolts.
Old Jul 3, 2014 | 12:18 AM
Car: RS Camaro
My apologies for needy questions, but how much taller are your "tall" valve covers
Old Jul 3, 2014 | 12:03 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
You need the narrow body rockers to clear stock centerbolt valve covers without modification. The PCV baffle is what is problematic. You could likely run these with stock valve covers if you remove the PCV baffle or get aftermarket ones that do not have the baffle.
Old Jul 3, 2014 | 02:55 PM
school boy's Avatar
thanks for clearing that up, my covers were quite a bit taller than factory.
Old Jul 3, 2014 | 09:24 PM
school boy's Avatar
Old Jul 6, 2014 | 07:26 PM
school boy's Avatar
bump
Old Jul 7, 2014 | 05:25 PM
school boy's Avatar
Old Jul 7, 2014 | 08:52 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
I'll do $50 without the poly locks.
Old Jul 7, 2014 | 09:35 PM
school boy's Avatar
pm sent
Old Jul 9, 2014 | 10:08 AM
school boy's Avatar
Sold to Steve Mack
Old Jul 9, 2014 | 11:11 AM
Steve Mack's Avatar
Car: 87 Iroc
Thanks Austin
Old Jul 11, 2014 | 12:46 PM
Steve Mack's Avatar
Car: 87 Iroc
Thanks Austin for the fast shipping.Parts are exactly as advertised.
Old Jul 11, 2014 | 01:21 PM
school boy's Avatar
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
