Extremely impressed with Berryman B-12 CHEMTOOL Carburetor/Choke Cleaner! (pics/w in)
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
So i had to replace the injection assembly in one of my vehicles, i noticed how dirty my lower intake was. I tried to clean it with a wire brush and some carb type cleaners that are made for cutting down gum, grease, deposits etc but the can of cleaner i was using ran out so i figured i would just pick up another one since i had to go to a auto parts store for something else anyways. I looked around and found this B-12 cleaner, i like to try new things and iv never tried B-12 cleaner so i grab a can to try out, i figured at best it would be the same as the one i was using. When i sprayed the lower intake it immediately started to dissolved and wash everything away, All i did was spray then whip up the liquefied deposits on the intake it took me 5 or 10 mins it was ridiculously effort less with no hard work involved at all and remind you the intake had heavy caked on deposits.
Here is a before and after. I wish i had pics of the how dirty the injector bosses where before i cleaned but i wanted to get this done and i wasn't expecting the lower intake to come out looking near new!
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Extremely impressed with Berryman B-12 CHEMTOOL Carburetor/Choke Cleaner! (pics/w
Wow. I've heard of it and always meant to try it but I just keep using the same stuff. I'll really have to pick some of that up next time I'm cleaning some parts up.
1 Post
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
That's impressive. I used some carb dip from autozone that was a complete waste of money. Thanks for sharing.
Good find!! I will have to try that out.
Car: 89' Camaro RS
Engine: 2.8 MPFI
Transmission: borg warner 5 speed
Axle/Gears: stock
I picked up a can a couple of weeks ago intending on cleaning out my egr valve with it. I ended up blasting my intake with it instead and was very pleased. The buildup was actually pouring out from the front of my throttle body. I didn't realize how much the over priced seafoam had been missing.
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Used it before to clean my LT1 intake and worked wonders. I have 4 cans in my garage.
I use brake clean a lot, bought some cheap stuff once and it took several cans and I thought wow this stuff is really caked on in my tpi intake. Used one name brand can and it cleaned it down to the metal.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I have used the Berryman's B-12 for years. It cleans very well. I have done many a carburetor not to mention cleaning engine parts. It can get a little pricey when doing real big projects like the whole of the outside of a friends engine block before painting but is the best that I have found. (It had caked on crud) I have used it to clean up paint mishaps also. I always buy three or four cans before I start a project that I might need some.
if u guys need to clean stuff u can pull off the motor to dip use pinesol with a about 25-35% water mix . i soak carbs and stuff in this mix and it works great and much cheaper then the alternatives
for really tough stuff dont add water , but ive never had to use it stright mixing it with water has always worked well for me
best part is it doesnt harm rubber and gaskets
edit
ahh crap i didnt relize how old this was
edit
Transmission: World Class T-5
Axle/Gears: BW 3.45
edit
edit
Car: 91 G92 Z28
Axle/Gears: 342
I started using the pinesol a few years ago when Berrymans went to a more environmentally friendly formula. Which means Berrymans no longer works any better than any of the other off the shelf carb/part cleaners. The Pinesol works well. I'd say not as good as the old formula Berrymans, but better than anything else I've tried. I use it strait up with no water.
