Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Quick Jack by Ranger/BendPak
Old 02-02-2014, 01:12 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Haven't posted in a while but I am changing the engine in my 1992 Formula 350 that has a rod knock. Bought a 1991 Corvette L98 with 41,000 miles on it to replace. I wanted to take my time and remove everything as carefully as possible. I though about buying a MaxJack from Bendpak and while on their website I found this.
http://www.bendpak.com/Shop-Equipment/QuickJack/
Attached Thumbnails Quick Jack by Ranger/BendPak-th.jpg
Old 02-02-2014, 01:13 PM
PAFORM350's Avatar
Engine: 5.7 L98
Re: Quick Jack by Ranger/BendPak
So I bought it and had to wait about 2 months to get it. Overall it looks good but unfortunately didn't come with any instructions or hydraulic fluid to set up. I sent an email to the rep I set the purchase up with. Waiting for an answer.
Old 02-02-2014, 01:14 PM
PAFORM350's Avatar
Engine: 5.7 L98
I wanted to take the transmission out from the bottom and the engine from the top. Either way I need to get under the car so that's the reason for purchase. We will see how this goes. LOL
Old 02-02-2014, 07:12 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
How much was it?
Old 02-04-2014, 04:07 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
isn't that cutting the weight limit close at 3500 pounds looks awesome keep us updated
Old 02-04-2014, 04:44 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
did you notice they dont show anybody under the car in all they're adds? i'd feel better with some jackstands under there too. kinda looks like a PITA that you cant get under the car from the sides if you leave it there?
Old 02-05-2014, 07:21 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Never been a fan of scissor jacks, great for the track, not so much for major work. Lift gets in the way a lot.
I have the maxxjaxx, they are great, only take a little install work. Just have to drill anchors with a hammer drill.
Old 02-05-2014, 06:57 PM
PAFORM350's Avatar
Engine: 5.7 L98
I paid $900.00 for it. I plan on setting it up and testing it tomorrow. I most likely will put a set of jack stands under it as well just to be extra safe
Old 04-09-2014, 05:13 PM
PAFORM350's Avatar
Engine: 5.7 L98
Finally got the thing set up. It works perfect and there is a whole lot of room under the car. All aspects can be worked on.
Old 04-13-2014, 09:44 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
the system has lock bars once lifted. I would determine once I got the lifts if I felt comfortable trusting the lock bars or using stands for backup if I bought one of these. also, if your in a simi limited garage the lift moves the car backwards when lifting so you would need to make sure your car is far enough forward as to not hit a wall or the garage door once fully lifted.
when I work on my FORMULA I like to have my car as far back as possible so I have the most room up front which is usually 10 ft from my box is why I thought about my last statement.
I may consider something like this. my ques is, is it taller than a trans on a trans jack? if not i'll stick with a floor jack on each side and raising one end then the other.
Old 09-05-2016, 10:45 AM
Jaseman32's Avatar
Car: 89 RS Gunmetal Gray
Engine: 350 TBI
The 3rd gen torque boxes are asymmetric (front narrower than the rear). How did you get this to work for a 3rd gen?
Old 09-05-2016, 11:39 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
A guy in my car club has one of these. A bit more pricey than the quick jack, but no hydraulic fluid or floor mounting required.
http://ezcarlift.com/
F-body-fan
01-12-2023 01:49 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
meeklay812
10-01-2015 03:46 PM
Galaxie500XL
10-01-2015 01:05 PM
z28joe2
09-28-2015 05:54 PM
Quick Reply: Quick Jack by Ranger/BendPak
