Miniram install question
1 Post
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Guys, doing a Miniram install on an 87 tpi IROC. Question is, I see some pics with guys that have a special bracket on top of the fuel rail to hook up the throtle cable. Do I need that? The kit only came with the on brracke that looks like it does both throttle and tranny but I think for some applications this special bracket is required. Any input?
Engine: 4++,350 & 305 CIs
Re: Miniram install question
The one on top is for your throttle cable. Its a must have part.
Bracket on the side is for TV and tom cruise control mounting.
If you bought it new, call TPIS and they will send you one right out if yours is missing.
Car: 1990 GTA
Then it maybe 89 and up, most likely with the difference in throttle body's, so yes I believe your right since the change over in cables was 89 IIRC.
84z96L31vortec
08-20-2017 12:16 AM
