hsr fuel pump
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
hsr fuel pump
well after more than 3 years I have my 383 HSR swap done. I got the sub frame in, new transmission, exahust, steering box and brace, suspension, ball joints, tie rod ends, ect ect ect.
I am trying to finally fire it up and now the in tank fuel pump wont fire after sitting all these years. The HSR came with a fuel pump. Can I just pull through the old one or do I have to drop the tank and pull it out? Just was hoping to avoid taking that exahust and everything apart to get there. UGH!!!! always a road block, nothing works first time.
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: hsr fuel pump
U could do the trunk access hole but that involves cutting the floor hump in rear compartment of the interior, theres a aftermarket pump that works with it i believe the company is wilbro look into them an they sell around 80-100 bucks an have a 1 year free replacement
Re: hsr fuel pump
i heard that banging on the tank and get vibrations in the tank can get a fuel pump going that has been sitting for a while. So the only option is new pump if that does not work? You can not pull through and old one?
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Re: hsr fuel pump
Re: hsr fuel pump
I'll do that tomorrow. The guy I was working with didn't show today. When I took the tip harness off I hope I didn't mess that up
Re: hsr fuel pump
If the pin out is the same as my 89 you can run a hot to pin g on the aldl and see if the pump runs. The fuse is near the battery, behind the headlight. One orange and one red wire.
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: hsr fuel pump
I'm not having any torouble with my Walbro 255, It should be able to support all that motor and it is still relatvely affordable.
Re: hsr fuel pump
Banged on the tank, put gas in it, and got the wires before the fuse and hooked it up directly. We have to bypass that relay I found out as the new wiring harness with the HSR has a seperate wire to trigger the fuel pump. The other wiring harness that I left on know I am wondering how many more electrical things are not hooked up in the dash
! Anyway fuel pump working thanks!
! Anyway fuel pump working thanks! Senior Member
Re: hsr fuel pump
Re: hsr fuel pump
oh I am so that guy. But we are wiring it to the ignition because I have help from someone better than me
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
