My Variation on a Single Plane EFI
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: My Variation on a Single Plane EFI
That is hilarious... Looks great! Lots of room for a few nitrous nozzles or to put a spray bar in there too.
We all want to see some engine specs and dyno numbers!!
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Nice welding.
I bet that either has crappy air distribution or great air distribution. At first I thought it might be problematic, but I think you have just enough overhang in the rear that it probably actually works better than a throttle body directly on the singleplane like mine. With that much plenum volume it probably responds very well on the street too.
Nice job!
-- Joe
Nice job!
-- Joe
Engine: 4++,350 & 305 CIs
Its not the prettiest but I'd bet it'll work very well!
Would have been nifty to bolt a cut up "fake" set of stock runners on each side just to mess with people.
Get that sucker on the dyno and show it off.
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Very interested in how well this actually works
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
That looks like a great idea. Some of the cobra intakes look like that and they make good power.
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
I like it.. Interested in how it actually performs..
Good work..
Good work..
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Nice, that's similar to an intake I've seen before (from Car craft rse 95)...
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
There's a lot going on there. Love the coil mount.
Car: `86 SS / `87 SS
Think of these two: LT1 has injector compensation for imbalanced air distro. Known issue; solved by programming. Runners are pulling off a hugely long plenum. Turbo Buicks can use a power plate to avoid rear cylinder overloading / lean conditions since they're boosted more than the front cylinders. Again, a fairly large, long plenum.
Now did he use a 2 x 4bbl tunnel ram to mod?
Car: 1991 RS
Engine: 5.0
I like the clamps over the oil breather holes. Custom.
Also that article says that bird has a Vette IRS, and gets 30 mpg too.
Engine: TPI 305/ v6
Article only states tunnel ram. The guy is a marine welder by trade.
My phone doesn't take awesome pictures but, I still have the Car Craft the snippet is from...
(and yes, ONLY the 3rdgen got the color spread)
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It's from the Real Street Eliminator Challenge. The T/A was beat on MPG buy a GN that averages 46.17mpg in the closed circuit course.
-- Joe
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
........ I don't have any dyno numbers yet ... every time I get the tune where I want to give it a go something else comes up ... lost the clutches in the posi unit and welded the spider gears to the cross shaft ... had to replace the diff carrier ... then lost the 3-4 clutch pack in the trans ... the breather hold-downs were a patch just to get back on the track ... kept blowing them out at 6500 rpm ... dang Chinese valve covers ... Current combo is 409ci with AFR heads , Comp solid roller , the power definitely moved up the rpm scale ... when I get the trans back in it'll have a 4000 stall converter up from 2800 ... here's another variation to see if smaller runners would help ... heard a lot of comments about plenum volume , but I think I'm still less than a Super Ram and my 8"-9" runners .........
Car: '87 Vette C4
Car: '87 Vette C4
......... Like this ? ....... the first version had plates that bolted over the port holes but the uneven distribution of screw holes caused it to leak ... I bolted on some fake runners to mess with people and to help seal the side covers ... since then I've just welded up the ports in the sides of the plenum ... makes a cleaner look ... most people don't even notice ...........
Car: '87 Vette C4
........ At full weight ... six speaker stereo , working A/C , and a trailer hitch on '87 vette and 2800 stall converter I was running 7.40's @ 92 mph eighth mile ... 60 foot times are up vs. the FIRST tuned port but I picked up nearly 4 tenths of a second overall with this intake and the switch from an XFI hydraulic to this street solid roller cam ......
Car: 1991 RS
Engine: 5.0
deadbird- I used to have that exact issue but threw it out years ago, along with a bunch of others I wish I would have kept.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
looks sorta like my Lingenfelter Elbow i have sitting on the shelf.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I wonder how this would stack up against the HSR? Probably would be pretty close
Any updates on this? Thsi seems like to good of an idea to let slip by lol
Car: '87 Vette C4
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
