Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Cold air intake for hsr
Old 04-23-2015, 12:04 PM
soarestransam's Avatar
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Is there any cold air intake made for our 3rd gens if so where can I get one the one i got off of ebay looks to ginnie rigged and sits way to high that i cant even close the hood
Old 04-23-2015, 12:53 PM
Re: Cold air intake for hsr
Also forgot to mention this is a hsr setup in a 88 trans am not camaro
Old 04-23-2015, 09:24 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
The eBay one I got works on my 87 formula with an HSR no problem
Old 04-24-2015, 11:42 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Make your own. I made mine out of 4" pipe from intakehoses.com. Get some couplers and bends similar to mine in the pic and get a big 4" k&n filter to put on the end.
Old 04-25-2015, 09:50 PM
Yea that looks really great compared to the one i got can u send me all the (part numbers/pieces) so i can order it up how much roughly did u pay for all it by the way
Old 04-26-2015, 02:34 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Bought it years ago so I can't remember how much. It is 1 90 degree turn and 1 45 degree turn with 2 4 inch couplers and a long 4 inch coupler.
Old 05-03-2015, 09:03 PM
nossbc's Avatar
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
this is the slp one
this is the one I made.
I also notice cooler temps on my iat compared to the slp
i made my own with 4'' pipe as well...I had slp plastic one before..it was a lil restrictive.
once at the track I decided to take out and try and it picked up a .15 on the 1/4.
so I decided to make my own in 4''
I used a 90* rubber elbow a 4'' alum pipe I had already and 4'' high flow filter...cost me around 45 for everything on ebay.
Old 05-05-2015, 07:24 PM
I would need mine to come out to at least tothe radiator support cause im running ac on mine ill figure it out eventually right now mostly focused on getting my ebl flash kit and LS1 spindles
Old 05-12-2015, 03:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I've always been curios on a 4" pipe cold air inlet with high flow filter vs carb with a decent cowl. Would there be a difference? I know the iat will show different temperature but performance wise?
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
stalkier
12-06-2015 11:25 PM
hayesaw0210
08-23-2015 11:15 PM
kyle5647
08-15-2015 11:56 PM
Quick Reply: Cold air intake for hsr
