bare essentials
Old 06-03-2004, 04:27 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
bare essentials
What you guys think......coolant overflow is the only thing I don't like.....got to find a way of getting rid of it.
Old 06-03-2004, 04:35 PM
nolanr0413's Avatar
Car: Trans am
ive seen ones that go on the side of aluminum aftermarket radiators, they are cylindrical and they bolt on or are welded on. I bet you could get something like that .
Old 06-03-2004, 04:44 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Yep, the cylinderical one..
need to find a picture of it somewhere, but it looks great.
Old 06-03-2004, 06:32 PM
406TPI's Avatar
Car: 1985 IROC-Z
here's another shot of my smoothed out plenum and hand made dist. cover.
Old 06-03-2004, 06:38 PM
JimmyG-91Z's Avatar
Looks Great! Just need to hide some of those wires now, looks like it's having a bad hair day.
And how did you go about smoothing the Plenum? Just sand/grind down the fins? then sand it smooth?
Old 06-03-2004, 06:44 PM
FLYNLOW92rs's Avatar
Maybe it's just me and my cliamte, but when i hear ESSENTIALS and don't see A/C anywhere, I get concerned.........
Old 06-03-2004, 07:19 PM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
very nice!
Old 06-03-2004, 07:30 PM
406TPI's Avatar
Car: 1985 IROC-Z
Jimmy.....bad hair day! I like that. Yes, you are right..I have a new set of plug wires ordered so I'll get them sorted out when I put them on.
As far as the plenum goes, I ended up clamping it to a sine plate and fly cutting them off on a bridgeport mill. I then sanded it smooth and polished after that. The cast aluminum dist. cover I had wouldn't work using that same method so I just cut out a new one from some sheet stock and bent it to match the plenum.
Flynlow...I would feel the same way if I lived in Florida too...but since I'm in Michigan it's really not that bad...we maybe have a few days in the summer when it gets above 90
Old 06-03-2004, 07:46 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
yeah your coolant tank sticks out like a sore thumb. it looks great though I like how you made the plenum smooth. never seen that before.
Old 06-03-2004, 08:07 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
it makes the plenum look like a custom sheet metal one. thats cool
Old 06-03-2004, 08:29 PM
devianb's Avatar
Looks really cool without all the accessories and smog equipment.
Old 06-03-2004, 10:24 PM
Sonar_un's Avatar
Car: '86 T/A
I hear ya, Houston is VERY hot. Forget about driving around during the day if your A/C isn't up to the task.
Old 06-03-2004, 10:30 PM
I'll vouch for that, When i drove through your state my windows were up and the a/c was on full blast....
(I'll admit my windows were up after being warned of the "don't mess with texas" signs all over the place, I got through there as fast as i could with my florida plate.....lol)
Old 06-03-2004, 10:53 PM
Car: Camaro
Engine: 355c.i.
Transmission: th350
not to get off topic, but it was 115 here yesterday
back on topic: 406 if you got a new reservoir that was actually clean then it wouldnt look bad either
Old 06-03-2004, 11:02 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I took mine out, and put in a Jaz brand one from jegs one that recirculates, its mounted underneath the battery tray so its hidden from sight, and works well. Ill try to get a pic later this week
Old 06-03-2004, 11:16 PM
This would be a great way to slove the problem as even with a new white tank, it would look horribly off-centered without another tank on the opposite side......
Old 06-03-2004, 11:19 PM
Engine: 383, L69
I have neither tank in my car, no need for a washer fluid tank, cant be having bugs on the window, gotta go wash it then
Old 06-04-2004, 01:19 AM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
Be Cool makes a nice one:
Old 06-04-2004, 05:19 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
do you have washer fluid resivour anywhere? You could easily hide the washer/antifreeze resivours. I dont like the top of the tpi. Is it raised or something?
nate
Old 06-04-2004, 05:40 PM
Kandied91z's Avatar
looks good, i think spending $8 on a new one would be a much better investment. without smoothing out all of the welds and filling in all of those holes the engine bay looks unfinished without the containers but that's just me. i'd put them back in but new and clean ones so that it looks much more finished.
great looking intake though, are you going to be at superchevy or camaro superfest?
Old 06-04-2004, 05:58 PM
406TPI's Avatar
Car: 1985 IROC-Z
Great ideas guys...I like the idea of putting it under the battery tray. Actually, I just starting making a tank today at work....it is 3inch by 3 inch hollow square tubing (10 inches long) that I tig welded caps on both ends.....All I have to do it put a vent in and the nipple for the overflow hose.....and polish it of coarse. I'll post pictures when I get it done.
Kandied...I "should" be at superfest this year...I haven't been there since they had it over at Domino Farms. I will be at Super Chevy in Martin.
I have bought plastic plugs for all the holes...just gotta paint them white and put them in.
Here's a pic of the outside of the car
Old 06-04-2004, 06:00 PM
I see you kept the bar essentials to the exterior as well, looks clean with no indication of what's under the hood.....
Kandied91z's Avatar
the plugs are a good idea.....my car won't be at superchevy unfortunately but it will be at superfest. i'll look for you at martin.
Old 06-04-2004, 06:14 PM
406TPI's Avatar
Car: 1985 IROC-Z
Dang you guys are quick on the draw!
Oh...suppose I should mention.. the 406 went south on me last year....she's just a 350 now with AFR heads.....
I have been meaning to change my profile.......
Old 06-05-2004, 08:32 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Very clean engine bay! I've seen several aftermarket overflow cans in Jegs and Summit that would look sweet in your car.
Old 06-09-2004, 09:07 AM
406TPI's Avatar
Car: 1985 IROC-Z
Thanks for the compliments guys!
Okay, here's the new tank I made...I think it looks better than that ugly plastic tank.
Old 06-09-2004, 09:08 AM
406TPI's Avatar
Car: 1985 IROC-Z
Another shot
Hey Kandied...doesn't look like I will make the Superchevy show this weekend due to unforseen circumstances..I WILL be at SuperFest though!
Old 06-09-2004, 05:43 PM
Kandied91z's Avatar
looks good, i still can't get use to the open space so i'm keeping my large containers for now but i do like how everything looks on your car. i'm already registerd for superfest, car 51 so i'll be there for sure all weekend long.
RedLeader289
05-28-2019 01:47 PM
Fanatic1074
10-02-2015 03:47 PM
RedLeader289
09-23-2015 06:50 AM
sreZ28
Carburetors
24
09-21-2015 04:54 PM
R13_Braz
09-18-2015 05:00 PM
Quick Reply: bare essentials
