December 2016 COTM **WINNER**
Old 11-30-2016, 05:39 PM
COTM Editor (Retired)
Linson's Avatar
Car: 89 Formula 350, TTA
Astounding Project. Amazing Car. Awesome Formula.
Congratulations, Lonnie P. Your '91 Formula is the TGO December 2016 Car of the Month Winner. The time, effort, engineering, and expense that has gone into the creation of this LS3-powered, beautiful beast shines through from every angle. I am proud to have Third Gens represented by your ride.
Car was a 3 year project which grew out of control very quickly.
What started as a paint job, grew to an engine swap, then a full on restoration.
By the time I was done, everything but the dash wiring was removed from the car.
Overall I'm very happy with the result. I won best modified in the 90-99 class at The Cabelas car show, which had approx 1500 entrants. On the 90mi ride there I got over 20mpg at 75-80mph.
Better than anything is the performance... I now have an 11sec car with incredible handling/stopping power, that I can drive anywhere. It started with 190hp & became a car that now buries the 140mph speedometer in 4th gear. Every bit of the car was built/assembled by myself with the only part being partially farmed out was the paint at my friends shop. I participated in every aspect of this as well, since I had previous experience working at a body shop. I just did not have a spray booth to achieve the quality of paint work that I desired at home, so I had to get some outside help.
Here is the link to the original build thread.
https://www.thirdgen.org/forums/ltx-l...swap-91-a.html (LS3 T56 swap in 91 Formula)
It evolved from my summer driver to a complete resto-mod style project over the 12+ years I have owned it.
I went in blind & gained a lot of knowledge with respect to LSx engine swaps & the nuances of the 3rd gen platform.
Thanks to all for the advice & tech help over the course of the project.
1991 Formula Firebird WS6
Engine:
2011 Camaro 6.2L LS3 (w/ 12 original miles)
Comp Cams Custom Grind
219/232 .622”/.620” 114LSA+4
Dual Springs & Titanium Retainers
FAST 92mm Throttle Body
Corvette Engine Accessories (AC, Alt, PS etc.)
2002 Trans Am ECM & Custom Harness
Programmed by Lonnie’s Performance
Approx 560HP (flywheel) / 6800RPM Redline
Exhaust:
Stainless Works 2” Headers, 3” Y & 3.5” Exhaust
Fuel System:
Lonnie’s Performance Custom Fuel System w/ Teflon Lines (-8 supply, -6 Return), Billet Rails
Fuelab Billet Filter & Regulator
2002 Camaro Plastic Tank
Drivetrain:
2002 Camaro T-56 6 Speed Transmission
Pro 5.0 Shifter, Z06 Vette Clutch
Tick Performance Master Cylinder
Strange Engineering Driveshaft w/ 1350 U-joints
Strange Engineering S60 Rear 3.54:1
35 Spline Axles, Torsen Rear
Suspension:
850# Front / 150# Rear Springs
36mm Front / 24mm Rear Sway Bars
Urethane Bushings, ½” Extended Ball Joints
Koni Shocks (double adjustable rear & single in front)
Fays II Competition Watts Link
De-la-lum Delrin/Aluminum Control Arm Bushings
UMI Frame Connectors, Rear Control Arms
Relocation Brackets & Strut Mounts
C4HD Corvette Front / 97 Trans Am Rear Brakes
13.2”Front/12.7”Rear Cross Drilled/Slotted Rotors
Hawk Pads, 1LE modified Hubs/Spindles/Bearings
No rubber bushings remain in the entire car
275/40-17 Nitto555 on American Racing 17x9 Rebel wheels
Body:
Original 50,000mi rust free body
Stripped to bare metal
Epoxy primed, PPG base clear in factory color
All new weatherstrip, upholstery, carpet & headliner
Modified stereo, w/ double DIN Pioneer APP radio, Amps & Alpine component speakers.
Car was done to appear stock, with minor visual mods to complement the engine & suspension upgrades.
Old 11-30-2016, 05:54 PM
russ&dars t/a's Avatar
Car: 92 Firebird Formula
Engine: 5.0 tbi
Transmission: 700r4/shift-kit
Axle/Gears: 4.11/posi
Re: December 2016 COTM **WINNER**
Congrat's Lonnie great ride
Old 11-30-2016, 06:04 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Congrats Lonnie! Awesome car!
Old 11-30-2016, 06:06 PM
82tarecaro's Avatar
Congratulations! Well deserved.
Old 11-30-2016, 06:20 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Congratulations! She's a beautiful bird.
Old 11-30-2016, 07:36 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Awesome on your win. Your hard work on detail pays off and it shows. Gives the rest of us that have lagged on our projects to get our butts in gear and continue on.
Old 11-30-2016, 08:59 PM
kymmee's Avatar
Congrats on the win! This car has so many highlights-the engine, the color, the wheels. Very unique and one of a kind! You should be very proud to own and drive it!
Old 11-30-2016, 09:14 PM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
Honestly the nicest modified thirdgen I have ever seen and i'm super picky (I also love your orange Formula too!!) Well deserved, awesome car Lonnie!
Old 11-30-2016, 10:35 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
awesome car congrats!
Old 12-01-2016, 08:35 AM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Congratulations, Lonnie! Your car is VERY well done, a great inspiration to myself and I'm sure to others as well!
Old 12-01-2016, 12:04 PM
kfsullivan's Avatar
Car: 1988 Trans Am w/ WS6
Transmission: 5-Speed
Congrats Lonnie.
You've done an amazing job with this car!
Old 12-01-2016, 12:34 PM
GASPEDDLER's Avatar
Great car, congrats!
Old 12-01-2016, 03:58 PM
SIXT8's Avatar
Car: 92 RS
Engine: 5.0 TBI
Transmission: 4L60
Axle/Gears: 2.73 open diff
Congrats! Beautiful car. Great job.
Old 12-01-2016, 04:07 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Congratulations. Beautiful work.
Old 12-01-2016, 09:01 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Thanks everyone for the kind words.
I got a lot of inspiration from the members here to build this car.
It took a lot of time & money to rebuild it, but fortunately these cars are finally starting to get some recognition.
Old 12-01-2016, 10:01 PM
Stuart S's Avatar
Congrats!
Old 12-04-2016, 03:37 PM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Incredible build, congrats
Old 12-17-2016, 07:31 PM
881SA's Avatar
Car: 1988 Camaro Z28
Engine: 5.7 / L98
Axle/Gears: 3.27 BW
Congrats on the COTM!!!
Love the color!!
Obviously a lot of work very well done looks like fun!
Ever had a chance to top speed that set up with the LS3???
Old 12-17-2016, 11:22 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
One of my very favorite cars.
Absolutely "Fantastic" build !
Old 12-17-2016, 11:26 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Well done, congrats!
Old 12-18-2016, 08:10 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
No, it only has a 140mph speedometer, but at my rev limiter of 6750, it should go 144 in 4th. All I can say is it buries the speedometer in 4th & continues pulling hard in 5th, but no actual numbers to share.
