Window/Door Rattles--Observation and Pics
#51
might as well bring this bitch back alive. so i was out trying to kill some rattles. on my drivers door, i traced a resonating rattle from that metal piece that is rivited onto the door that holds the arm rest. what i did was take like a square inch of paper towell and roll it up. than i took a screw driver and pried the top out a little bit and than jammed the rolled up paper towell piece into the gap, than i used a real small screw driver to push it a little deeper so you cant see it. i done this on both doors and oh man, what in improvement. and one other thing i had noticed was that the metal pieces for the door lock and door latch rattle. i already replaced the foam as described earlier but they still continue to rattle. in the pictures above, the rods have a sleeve on them, mine do not have this. the plan is to find something to put over the rods so they do not move as much while shutting the door.
#52
Recently, I discovered another possible source of noise: the A-pillar retainers and their clips. After being subjected to the sun for many years, the plastic of both the pillar and the clips can become brittle and, as a consequence, break.
The pillar, if my parts man is correct, is no longer available from GM. As I recall, it wasn't available from Year One either. As can be seen, I did attempt a fix to a retainer, one that probably would have worked, but I ended up harvesting the entire pillar from a bone yard for $5.00.
JamesC
JamesC
#53
Here are the five clips, two Christmas tree type for the lower portion of the pillar and three for the upper. The three upper are more suspectible to breaking, I think. Once the center portion snaps there is nothing to keep them in place.
JamesC
JamesC
#55
Sorry. The first version looks very similiar to the ones shown here, but the base, which is also suspectible to breaking as you see, is even more feeble (82 to 84 cars?). The newest version has a rubber insulator--again GM must have been aware of noise problems. That version can be seen on the following thread (thanks CC_HotRod for the pic and TomP for a good how-to reply):
https://www.thirdgen.org/techbb2/sho...llar+and+clips
JamesC
JamesC
#56
One of the Christmas tree clips in place. I bought new at CarQuest.
Note the weather stripping. I stripped and reglued, then liberally doused it with silicone to guard against its drying out and cracking.
JamesC
JamesC
#57
The upper clip is still available from GM (part number 20462090), the type with insulator as shown in the above thread.
Hawk's now sells the above as well:
http://www.hawksthirdgenparts.com/pr...rd-New-GM.html
JamesC
JamesC
#60
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Wow, I'll sure use this thread when I get around to "rebuilding" my doors from the inside out.
#61
Car: surprise!! a '92RS!!!
Transmission: 5 speed "M39"
Vacuum hose!!!
Tyler,
Buy a coupla bucks worth of vacuum line---I don't know the exact size but you can eyeball it.
Probably 10 feet would do every linkage rod in both doors one and a half times.
Cut off a foot-long piece and slit it, then slide it onto the rods.
Also, there's a place about a foot or so from the rear of the door where two rods run right next to each other. Sorry, I finished this job last week and buttoned up the door, but I think the two rods are the one from the door lock slide and the one from the door latch handle. One of them was real loose and rattle-y. What I did was a little funky, but might work for you. I wrapped a nylon zip-tie loosely around both rods, just snug enough to stop the rattle, then I greased the snot out of the rods so the zip-tie can slide. Come to think of it, I greased about every d*mn thing in there except the glass.
My door sounds great now.
Oh yeah. One more thing. If your door has the nylon striker plates (later models, I think), make sure they are right up snug against each other when the door closes. Mine were like 1/8 inch apart. Factory uses thin spacer shims, you can make them out of anything. These do a really nice job of holding the door tight. The plates I'm talking about are a couple of inches below the top of the door and in the matching spot on the jamb. They're angled to slide up tight against each other when the door closes. If your car doesn't have them, grab a pair off a yard dog and put 'em on.
You'll love 'em.
You'll love 'em.
#63
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Awsome post man, get the mods to make it "sticky"
You have any tips fro removing window rattling? I assume I need to take the door panel off and get in there and tighten it up? what all do I need to tighten and should I try to use some thread lock?
#68
Car: 1985 IROC
Engine: TPI
I found the bump stop in the bottom of my 85 door. Where does it go?
#70
Car: 1985 IROC
Engine: TPI
Still not finding it. Mine is an 85 not an 05 as I previously posted. Is it in one of the shop diagrams. Sorry, I'm new at this...
#71
1 Post
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Originally posted by okfoz
I think 87 was a big year for a lot of those improvements, to help reduce rattles. I know mine had most of those from the factory EXCEPT the Lower Door rubber piece that he describes (Got one from another car, makes the door close harder but it helped with some squeaks. I think my 91 had it tho...
John
John
#72
The FAQ link provides much more info. Please post there.
https://www.thirdgen.org/techbb2/sho...hreadid=226909
JamesC
JamesC
#75
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
this is great!! I really hope that someday someone makes a complete door rebuild kit with instructions so one can order everything they need in one sweep
#77
1 Post
Another great related post
https://www.thirdgen.org/forums/body...hab-resto.html
#78
1 Post
Lower Hinge info
Some lower hinge info:
The lower hinge contains a pin with a roller on it. Many times the roller gets destroyed and starts popping. One member found that you can just replace the pin and roller, saving you money since new lower hinge is about $100. Also new lower hinges do not come with three holes drilled, just two. My 88 Iroc was a three hole lower hinge.
Roller: GM Part#20058035
Pin: GM Part # 20262500
See attached picture
Entire hinge can be purchased at Hawk's (site sponsor)
Other pictures show how the failed roller destroyed the pin.
#79
1 Post
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Originally Posted by Mylilbowtie
I have a cheap way to make plenty of those plastic pieces. Just goto home depot or ace hardware or lows and get some pvc line in the diameter that you need and cut to length and have plenty left if you need more or mess up.
pvc would be too thick
and it would crack since it's not very pliable
#80
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
The rear seat striker cover on the door striker is a brilliant idea! I did it today and works like a hot damn.
Between the sfcs I recently installed and that, I have a new found love for cruising in my t-top car!
#81
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
If anybody hasn't seen the group purchase post for repairing the upper/lower hinges on sagging doors, check it out!
The GP is almost complete so hurry!
https://www.thirdgen.org/forums/grou...epair-kit.html
#82
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
One thing to check if your door rattles, I don't know if it's been mentioned in this thread or not, if you have manual mirrors, check them and see if they're lose or if something inside is lose. My passenger door always rattled since I bought the car and I could never figure out what it was, when I was swapping out my mirros with the power mirrors I noticed the mirror rattled a little when I set it down. So I closed the door and no rattle!
#83
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Also, when installing the window regulators with (2) 1/4" bolts, I used star washers behind both the bolt heads and the nuts to prevent loosening over time.
Since the weather seals were missing from both doors, I cut new ones from 3mil polyethelene and then cut new sound deanenders from a sheet of polyurethane underlayment.
The result is that the doors now have a rock solid sound when closed and the ride is much quieter.
#84
1 Post
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I have not yet started to do this but thanks alot.
my question is that it seems as though when i shut my door with my window down it seems to be more rattely then with it shut... any ideas as to why, i would like to gather up as many parts needed as possible before taking of my door panel...
Thanks again,
Dennis
Thanks again,
Dennis
#86
With window up the glass hits the weather stripping all around and so cannot rattle.
Even with my new outer glass seals I still notice a little rattle when I shut the door with the glass down. Maybe I need to adjust the felt pads a little to take this out, not sure till I try it.
#87
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I notice that hwen I close the doors with the windows up or all the way down there is no rattles... With the window partially up I get the window rattle...
JOhn
JOhn
#88
On my '88 there are several "tracks" in which the regulator and window run:
-one along the bottom of the window
-two bolted to the inner door skin
-the front channel in which the window moves
If any of those components is loose you will/may get some rattle.
#90
I dunno about my thirdgen I havnt messed with it in awhile but my 4th gen would rattle with window half way down. I checked everything last night and found what it was. It was the guide/roller towards the rear of the door I could grap the bracket the roller attaches too and where the roller was riveted on well that was loose. My temp fix was to cover the connection with strip calk. Later on I can take it all out and put a screw in there with some red thread lock.
#91
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I plan on buying these when I do my doors. Maybe I'll fix mine now but when I want to replace everything I'm buying these
http://www.eharwood.com/catalog/prod...?productID=117
http://www.eharwood.com/catalog/prod...?productID=118
Then these
http://cs21.simplehost.com/%7Epercys...d=43&Itemid=57
1/4" Front w/ all others 1/8"01137-42$ 1,295.00
This is next winter though when I do my body work. THE WHOLE UNDERCARRIAGE will be worked on. Its not a bad setup if you want to loose tons of weight. Just watch out.....the lexan is illegal, and fiberglass is easier to break than steel.....hope you never get into an accident.
Then these
#92
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Then these
Then these
Price: $320.00
Is that just for a door skin, or a whole complete door?
#93
Car: 89' IROC-Z
Engine: LO3
As far as I know its for the complete door.....minus everything like door panel (internals) door handle. But it is for my IROC so I dont have to buy rocker panels.....YESSS, and not to brag but $320 for a light *** door......WELL WORTH IT. I want these doors so I dont have to worry about my door sagging anymore (much really), and it will be WAYYY lighter than stock doors. Im e-mailing them now to find out weights of their products.
EDIT: E-MAIL SENT
EDIT: E-MAIL SENT
#94
Engine: 4++,350 & 305 CIs
I have found a few fixes myself.
Subframe connectors are a must.
Step 1 is to fix the hinges if there is a problem.
Step 2 is install the plastic wedges on the body and doors from a 92 ish car to make the door more solid
1st is the rubber stopper for the bottom of the glass. Its usually rotted, rolling around the bottom of the door shell and makes the door sound like a box of toy pinball machine parts when closed with the glass all the way down..
I used the rubber mounts found on a fox body mustang air box to fix mine.. (87-93)
Its the 2 upper rubber air box mounts that we are stealing. It has a threaded side with a washer molded to rubber another washer then more threads. They come with their own nuts. I cut off 1side of the stock screw/washer assembly and that leaves you with a perfect studded rubber stopper replacement ..
drill out old rivit on the lower center door glass bracket and install the rubber part (rubber down, stud up) from stang. you may have to drill the bracket a tad bigger for the stud.
Another is a metal brace the runs inside along the upper part of the outer door skin above the door handle. Over time it comes in contact with the door skin and rattles after the door is shut. If you put your hand on the metal it will feel tight but if you pull on it gently it will seperate away from the skin, thats where it rattles when closed. I just use high density foam or old bike innertube between the parts and no more rattle..
#95
Re: Window/Door Rattles--Observation and Pics
primer u said u had the website to BTW SoftSeal weather stripping
#96
Car: 1985 chevy camaro
Engine: V8 305 5.0
Hi, I have a 1985 Chevrolet Camaro Berlinetta, here’s a link to see it http://www.cardomain.com/ride/3088924 and the 3rd to last row you can see were my glass from the driver side window is chipping away at my car and that mark you see is from a metal Piece of my car. I don’t know how the glass hasn’t cracked but every time I closed the door it hits there. I don’t know much about cars, so I need some help. Can I just adjust the hinge or do I replace it. Also can someone tell me what’s that thing I’m holding in the 5th from the bottom picture? it came from the top of the car
#97
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
I've been working to sound deaden my doors for the last few weeks, but the main problem have been to manage to locate the sounds. Now, I've found door handle hinge slop, door handle bracket slop, rod slop,various bracket slop, but still after fixing all of that, it STILLL rattles!
Anyway, today I found a new source for the "clunking" I have alot of; The centre pivoting point for the main window mechanism. Seems it's just some kind of steel rivet that works as the bearing there. So it may be hard to fix, given to replace, it needs to be both flush, not too tight, but tight enough to eliminate slop etc..
I found this big slop by driving without doorpanels, having window maybe 40% down, then you may push and pull on a big white plastic piece that hodsl the window towards the sideview mirros, and then you'll both hear the flop, and see it.
I think we need some kind of brass bearing kit, like the door hinge fix. Anyone got an idea on how to fix that and still keep it so flush it wont hit glass or door itself?
Maybe some locksmith bolts cut to length could do the trick...
#98
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock?? I'm not sure
It's been awhile since this post has been opened, But I always seem to find reasons to bring back old stuff.. I have all clips off, well im 95% sure. Up on the top rail, it's the only thing holding the panel off, I'm trying to get it out of the way so I have full access to the dent in my door, I wanna try and push the dent out but I don't have the right angles with the panel on. I can bend it, but I don't want to. The panel slides slightly left and right, but something is keeping it on at the very top, any ideas??
#99
JamesC
#100
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
i really must be lucky. my 84 z28 has no rattles, at least that i have noticed. then again it does only have 84,000 miles, was owned by an old couple and was garaged for years.
now if only i could do something about that rust =[
