Panel Rust Crap
Car: 1988 and 1987 Trans Ams
Panel Rust Crap
Hey Guys,
What do you recommend I do with these?
Looks isn't a big deal, most of the rust is going to be underneath GTA ground fx.
How do I treat it/keep it from rusting again?
1 Post
Car: 1991 GTA
Engine: LB9
Re: Panel Rust Crap
Something like that I would replace the whole piece, or weld in a patch panel.
If you are set on using that as is, I would coat it in POR 15.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Panel Rust Crap
I would try media blasting or possibly something they call rust electrolysis. Not sure if you can do part of a panel on the latter.
Car: 89 GTA
Engine: 5.7 TPI
Re: Panel Rust Crap
Order a new panel and just trash that one. Classic sells new front quaters at $150 a pop.
http://www.classicindustries.com/pro.../10081965.html
Car: 89 GTA
Engine: 5.7 TPI
Re: Panel Rust Crap
I will add though if you plan on getting the fender get more as it's shipped truck freight. So you'll want your money's worth out of it.
Re: Panel Rust Crap
Yeah, but aftemarket from clasics for camaros sucks.not sure on gta... Like stated above, you need to media blast that and get into the pores. Get all the rust out. Or I think por15 will kill it.... But if you wont see that, you can por15 it, and then use filler (bondo) to smooth it out, prime/paint.
Car: 89 GTA
Engine: 5.7 TPI
Re: Panel Rust Crap
This is them.
But like I mentioned before if you do consider this buy more then just one fender as they will ship it truck freight.
Just a heads up I myself plan on getting the same fenders as you are because I too like the air vents.
Re: Panel Rust Crap
rear aero wing and louvers are A LOT different than a fender my silly friend....
WHAT I'M TALKING ABOUT is the fenders I'VE gotten and heard from other people here that classics fenders are junk. Mine was sooooo far off that if it had teeth, it could eat a apple through a chain link fence... Waste of money...
Maybe for gta's the fitment is better....
Re: Panel Rust Crap
It's gonna be covered by ground fx, so unless it's going to bother you, I wouldn't worry about replacing it. It doesn't have any thru-holes. Spend some time with a wire wheel, prime it with some converter, let it sit for a day, repeat. Then give it a coat of paint and cover it over. It's just one of those things that noone will know about but you, and if you ever want to replace the fender you know that you can.
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Re: Panel Rust Crap
Clean it REALLY REALLY good, if you have access to an air compressor, buy a small sand blast tool from harbour freight or northern tools, blast the rust out of the pits, coat it with por15, this will stop the rust, then prime over the por15 and hit it with some spray paint. Do not leave any bare metal on any step.
Car: 1986 Trans Am w/WS6
Engine: 305 (5.0) TPI
Re: Panel Rust Crap
I used the Loctite Extend Rust Treatment on mine.
http://shop.advanceautoparts.com/p/l...192/10189462-P
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Panel Rust Crap
Just throwing this in as an alternative to welding in patch panels. Had a couple of panels put in my S10 using this stuff and you can't tell the truck had any work done. No hot welding on your vehicle in tight spots. GM approves of it for this purpose.
http://www.pliogripbyvalvoline.com/nr.php?id=7
Re: Panel Rust Crap
Well, give us an update in six months to a year to see how long the product worked. I'm all for not welding but that metal looks badly contaminated.
I do hope it works out for ya.
Good luck!
Good luck!
Re: Panel Rust Crap
If it was me I would blast it with a small gun, POR it, prime, filler, and finish it. I had the same issue on my '86 IROC and when it was done you never would have known it was there.
Re: Panel Rust Crap
That doesn't look bad at all. Hit it with a wire wheel or buy one of the sand/abrasive blasters as mention and hit it up til it shines, slap some primer on and paint.
OR....wire wheel/blaster, rust treatment, por15. I honestly don't know if the por15 works, but I'm doing my floor pan with it now. I do know someone who did their trunk in a classic car and the rust, after 8 plus years, has never shown back through.
1 Post
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Panel Rust Crap
If the rust has not actually perforated through, good surface prep will suffice.
If you want a long-lasting repair, wire-wheels will not de-rust as well as
media blasting. If you have an air compressor, Harbor Freight has some
economy blasters. However, a modest sand-blaster will become as useful
as a power washer.
After de-rusting, there are several options available. POR-15 is an awesome
product, but needs a tie-coat if you want anything else to adhere to it.
Check out their web-site. Eastwood also offers a lot of good products, check
out their website. I personally would go w/ a type of epoxy primer, then
standard polyurethane paint primer.
If you have perforations, all bets are off. If anybody's interested, I can
share a tale of woe about that experience.
Good luck, and keep up posted.
kk
as a power washer.
kk
Re: Panel Rust Crap
If you dont want to buy a blaster... get a couple gallons of muriatic acid and submerge/soak the rusty parts. They will be 100% clean/bare steal in a day. I clean my bolts and other small parts this way when I dont want to blast or its to hard to hold the piece..After a long soak, rinse with water. you must treat the bare steal immediately or it will surface rust.
When done with acid, pour it back into the jugs. you can reuse it a bunch.
Engine: 5.0 Tbi
Re: Panel Rust Crap
I swear to god officer the barrels of acid in my back yard only have car parts in them............
Re: Panel Rust Crap
I use it to clean lots of stuff. Its a fairly mild acid, so you can get away cleaning softer materials too.
I use electrolysis to clean metal too. Takes a while but it gets every piece of rust.
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-22-2015 08:28 PM
