Differences between hinge repair kits
Would like to know the differences between the kits
http://www.ebay.com/itm/New-1982-199...736fff&vxp=mtr
http://www.hawksthirdgenparts.com/bu...lower-pin-kit/
why is the hawks kit $60 more? is the quality that much better? only want to do this job once, which brand do you guys recommend?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Differences between hinge repair kits
I used the $ 74.00 standard kit 9 years ago and still going strong.
= http://www.top-downsolutions.com/Bod...y-and-Interior
Part of the difference is that heat treated/machined bolt.The quality of the steel looks way better than the doorman piece.The 12pt nuts & bronze bushings also add to the cost/quality.The remaing price diff has more to do with profit/overhead.
2¢.
I bought the same kit as Ron some 15yrs ago.Still waiting to use it too.
2¢.
Engine: TBI,5.0
I think this description of the TDS pin's says a lot =
Kit Contents: (2) Shouldered machined 4041 steel pins, electoless nickel plated for improved lubricity and corrosion protection. (2) Machined Phosphor Bronze flanged bushings, (2) Aerospace 12 point high tensile nuts.
I like it when they can print that kind of information.
Just the nuts alone will tell the story. The other kits look like there's came from a hardware store.
I highly recommend the "spring" tool.
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
I've used both and would use the Dorman kit again. I purchase the TDS greasable kit about 5 years ago and loved it. However, I do believe it is overkill. The Dorman kit is under $10 and having installed them last weekend I'd say save your money.
See post 70 of my build thread:
https://www.thirdgen.org/forums/memb...n-91z-ls1.html
