Project Procrastination '91Z LS1/T56/currie 9" w/PICS
Old Jun 2, 2014 | 12:20 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
This might get lengthy, but I'll do my best to make this as readable as possible.
I bought an '86Z in 2009. This is it at a car show:
It had a well-built 355, 700R4, 3" fiberglass cowl hood, and ran very well. I did a T56 swap a few months after buying it. Also built a Currie 9" for it. Here's a thread I made of installing the gears:
https://www.thirdgen.org/forums/tran...-your-9-a.html
Then I noticed how bad the floors were. Around this time I found a complete '99Z LS1/T56 car:
So I sold the engine/trans from the '86, to pay for the '99. I pulled the LS1/T56/fuel tank, and sold the '99 as a roller.
So at this point the '86 had no engine/trans, just the Currie 9". I also now had a complete LS1/T56/plastic fuel tank.........but no car to put all these parts into.
So one night I'm trolling craigslist and I found a '91Z shell that had been mini-tubbed. It was bare, but had FAR less rust to contend with (compared with the '86) had already been mini-tubbed, and only cost me $200. There ended up being more rust to deal with than I had anticipated, but it's been dealt with. It was a chore to get it home, but I made it happen. Here's a thread I made about the car:
https://www.thirdgen.org/forums/body...tub-shell.html
First thing I did was tackle the rust in the floor. Here's the thread of that repair:
After I fixed the rust the car just sat in my garage......
Until last year when I decided to build a rotisserie for the body. Some of you may have seen the thread, but here it is anyway:
https://www.thirdgen.org/forums/body...otisserie.html
After I built the rotisserie I cleaned/degreased the bottom, then it sat. Again......
So now to the present! I finally decided to do some real work on the car, and I'm happy to say that the bottom/floor is FINISHED. Let me walk you through what I did over the last week and a half.
I started by patching the 7 body plugs. There's also 2 more above the fuel tank, but they're seam-sealed and I didn't feel it was necessary to do them.
First I pulled the plugs:
Then scrapped away the sealer from the inside:
Then cut out the entire area so that the patch would extend over the entire area:
Cut out the patch:
And welded it in:
Here's one of the round plugs underneath the passenger seats:
Also, it looks like the car hit something that tore up this area:
So I worked the metal back into place and welded it:
Then I had more work to do on the floors. Cutting out ANY rust and replacing it with new metal:
Old Jun 2, 2014 | 12:21 PM
Car: '91 LS6/T56/9"
Engine: LS6
Re: Project Procrastination '91Z LS1/T56/currie 9" w/PICS
After that I went back and sandblasted all of the areas of previous metalwork to get rid of any rust that had accumulated:
Once all that was done, it was time to prep for paint. POR15, followed up by Rust-oleum undercoating:
I cleaned then etched the entire bottom of the car:
The painted with POR15:
I did 2 coats, then finished with a the Rust-oleum undercoating:
And that's where she sits right now.
Old Jun 2, 2014 | 07:58 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Very nice! I love the home made rotisserie too.
Old Jun 2, 2014 | 10:02 PM
Car: '91 LS6/T56/9"
Engine: LS6
Thanks. This much floor work wouldn't have been possible without that rotisserie!
Old Jun 3, 2014 | 09:41 AM
Car: '91 LS6/T56/9"
Engine: LS6
Yesterday I bought some Lizard Skin sound-deadening insulation (2-gallons) along with the accessory kit from Summit. Should be here tomorrow.
I'd also like to provide some details about the work done so far since I kind of skimmed over a lot yesterday.
First, the body/floor drain plugs - From what I understand they were only designed into the cars floor so that liquid would drain from the car during manufacturing. You'll notice that they're sealed with some kind of sealer from the inside which also holds the carpet in place. I saw these as just unnecessary holes in the floor, which is why I patched them.
Patching holes - Because you're welding thin sheet metal you have to make your patch almost perfectly contoured to the hole it's covering. When welding, staying in one spot too long will cause burn-through so move around to avoid this. You can also cool the weld with compressed air or a damp rag.
POR15 - This stuff is no joke. WEAR GLOVES. If you get it on your skin, you can easily clean it off with mineral spirits. I used gasoline too. However, if it dries on your skin it is NOT coming off! I had some dry on my fingers last week, and it's almost completely worn off by now. So if it happens to you don't sweat it, it'll wear off. I applied the POR with a $3 3" paint brush. This stuff drips too, and if it gets on your concrete it's NEVER coming off! 2 coats is a must. 1 coat looked fine, but after I did a second it was clear that 2 was the way to go. I cannot imagine working with this stuff with the car above me. Just having my car sideways on the rotisserie was somewhat challenging. Last thing, you must prep your surface properly. Clean/degrease then etch before painting. I etched the entire bottom of the car for over 30 minutes keeping the metal wet by continuously spraying in different areas. 1 quart was enough for 2 coats. I now have a second quart that I haven't touched.
Rust-oleum rubberized undercoating paint - This stuff cannot be sprayed from a paint gun! The can says to use a hopper style gun, but that's a lie.........I tried and it won't even spray. Simply too thick. This stuff is like thick chunky peanut butter. I used it to protect the POR (which will breakdown over time if not top-coated) and for it sound-deadening properties. While I only used POR on the floor, this stuff was used on every surface that faces the ground. Also unlike the POR I had to use 2 quarts for 1 coat. First thing I did after the POR dried was apply a dust coating of this product in its spray can form. 2 cans did the trick.
Followed by 1 coat (using 2 quarts) in paint can form. I also brushed this product on using a 3' brush. It's very thick and covers well.
Sandblasting - I bought a small sandblaster a few years ago and haven't touched it until now. Since some of my previous metal repairs had rusted a little I decided to remove as much with my grinder and abrasive wheel as I could, then sandblast the rest. This thing worked very well, but sand gets EVERYWHERE! From the track of your garage door to the crack of your *** I mean EVERYWHERE! Wear a hood and ling sleeves too. I bought a cheap sandblasting hood a while back that helped.
Old Jun 3, 2014 | 01:02 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Subscribed!! Followed your rotiserrie build! Nice work bud!!
Old Jun 3, 2014 | 02:37 PM
Car: '91 LS6/T56/9"
Engine: LS6
Thanks. I'd love to see someone build another one. The goal of course is to get the car off the rotisserie and possibly sell it to another member.
Old Jun 3, 2014 | 05:43 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Subscribed! Take two!
Old Jun 5, 2014 | 09:49 AM
Car: '91 LS6/T56/9"
Engine: LS6
Lizard skin got here yesterday.
Old Jun 8, 2014 | 10:47 PM
Car: '91 LS6/T56/9"
Engine: LS6
Ok Lizard Skin is on. The discoloration is just because I took the pictures as it was still drying.
Good product. Went on easily, covered well, and cleans up with just water. I still need to do the doors with it so I might buy another gallon.
Old Jun 23, 2014 | 03:02 PM
Car: '91 LS6/T56/9"
Engine: LS6
No progress last weekend.
I'll be making my own outer subframe connectors, and emailed Alro for a quote.
http://www.alro.com/
BMR said they could sell me the material bare and un-welded, but it wasn't exactly cheap. So I emailed Alro in Melrose Park (I'm in Chicago) for a quote on 24' of 2"x1.24" .120" wall rectangular tubing.
Quote was around $150 picked up. Is that fair? Cheap? Expensive? I know it's more than I need but I'll be using some of it to brace in other areas too.
I also cut the inner subframe connectors (Alstons) off of the '86 (the first pic in this thread) intending to use them on this build, but now I'm second guessing myself. I planned to connect them to the outers I'm building, but I'm worried they'll become a problem with the car lowered.
Also, I'll be using a crossmember mounted torque arm (like the BMR Trac Pak) that mounts a crossmember between outer subframe connectors. I've never seen that crossmember mounted to INNER SFC's......has anyone else?
Old Jun 25, 2014 | 10:10 AM
propaintball96's Avatar
Keep it up man looks good!
Old Jun 27, 2014 | 02:51 PM
Car: '91 LS6/T56/9"
Engine: LS6
Thanks, I'm trying to keep the momentum going and not let it sit too long.
Old Jun 27, 2014 | 02:52 PM
Car: '91 LS6/T56/9"
Engine: LS6
Today I bought 2 12" sections of 2"X1.25" rectangular steel from Alro in Melrose Park. $80 picked up.
I'll be building my outer subframe connectors with this.
Old Jun 30, 2014 | 09:18 AM
Car: '91 LS6/T56/9"
Engine: LS6
Started on the outer SFC's yesterday. Here's what I started with:
Starting with the passenger side I decided to keep them tucked close to the floor which meant making 2 sections so that the front will line up with the front subframe:
They won't hang below the floor which is why I went with outers VS inners:
Drivers side. The drivers side is one solid piece running the length of the rocker.
I still need to make angled mounting points for both side to connect the the front subframe. I'm still not sure If I should make a piece to fit around the control arms, or just weld it as-is. What do you think?
Old Jun 30, 2014 | 11:46 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
How heavy is that steel?
I like the potential that those have.
Old Jun 30, 2014 | 12:22 PM
Car: '91 LS6/T56/9"
Engine: LS6
I haven't weighed anything, but it's the same material that UMI uses for their SFC's. I believe BMR too.
I should have gotten a lot more done yesterday, but it was hot and I was feeling lazy.
Old Jul 7, 2014 | 09:05 AM
Car: '91 LS6/T56/9"
Engine: LS6
Got some more done on the subframe connectors this weekend. Still need to get a trans crossmember bolted up before I make the angle piece that'll weld near it.
Old Jul 7, 2014 | 12:35 PM
Car: '91 LS6/T56/9"
Engine: LS6
I also spent some time making the garage nicer to work in. Since parts for this build are split between the garage and shed, I decided to add shelving to my shed so I could store everything in there. This way I have more room to move around in the garage.
From the garage I was able to remove:
- 700R4 (great trans and need to sell. Only pulled it for a T56 swap years ago)
- 4l60E (picked it up for $50. couldn't pass it up)
- T56 (LS1)
- Both 91 Formula doors. (got them for $50 at a discount weekend at the local parts yard)
- Plastic fuel tank
- Heads
- radiator/fans
Went from this:
To this:
Old Aug 2, 2014 | 04:28 PM
Car: '91 LS6/T56/9"
Engine: LS6
Slight detour. I found a Trans Am part-out local and couldn't resist. I picked up the engine/seats/fuel tank.
Then I had to build another engine stand/dolly/cradle. Bought a SBC one off ebay then moved the front mounts back a few inches. Here's the pics:
Car: '91 LS6/T56/9"
Engine: LS6
Old Aug 9, 2014 | 04:24 PM
Car: '91 LS6/T56/9"
Engine: LS6
Got some work done on the subframe connectors today. Finish welded the passenger side, just need to add one more tube, clean, paint, and weld in.
I Tig welded this so the bead wouldn't push the tubing away from the cars subframe. First time I've ever Tig welded on a project. Practiced a little before hand, and didn't come out half bad.
Old Aug 9, 2014 | 05:08 PM
texascat2's Avatar
Nice welds!
Old Aug 11, 2014 | 10:22 AM
Car: '91 LS6/T56/9"
Engine: LS6
Thanks. Tig isn't hard either. Just a little practice is all it takes. It's just soldering on a larger scale.
I've been putting off adding the last tubes to the crossmembers because I don't have the trans crossmember in place yet. I'm also on the fence about using my inner connectors and connecting them to the outers with tubing. I'm concerned they'll bottom out on a lowered car. However, this car won't be slammed so I'm just not sure yet.
Old Aug 13, 2014 | 02:58 PM
Would you mind posting a close up picture of the Rustoleum Undercoating? I am debating whether to use Rustoleum, EZ Liner, or Al's Truck bed liner for the bottom of my IROC...
Thanks!
Old Aug 13, 2014 | 03:25 PM
Car: '91 LS6/T56/9"
Engine: LS6
Sure I'll take one later.
Old Aug 13, 2014 | 09:11 PM
Car: '91 LS6/T56/9"
Engine: LS6
Old Aug 17, 2014 | 06:39 PM
Car: '91 LS6/T56/9"
Engine: LS6
Ok the subframe connectors are done.....well as done as I can currently make them without the plate steel I need to finish the rear sections.
Denny from thirdgenranch hooked me up with a stock transmission crossmember that I used to make sure my design wouldn't hit it. I'll be using the stock crossmember to build my own for my T56. I'll link to that thread whenever I get to making it.
Old Sep 4, 2014 | 09:43 AM
Car: '91 LS6/T56/9"
Engine: LS6
Little update. I started sanding on the engine bay to prep for primer/paint, and get rid of some lizard skin over-spray. I've been sanding with 60, 80, and 100 grit.
A few areas had small amounts of rust that I couldn't sand off so I used some rust treatment. It did an excellent job.
The epoxy primer and primer surfacer are almost ready to go on.
Old Dec 14, 2014 | 08:44 PM
Car: '91 LS6/T56/9"
Engine: LS6
Got a minor update. Since i got a few questions about how I initially got the car onto the rotisserie, I thought I'd document how I got it off.
Since winter is here and will snow soon, I decided to take the car off the rotisserie so I could stack cars and park my 4runner in the garage.
All of the work that I needed the rotisserie for is done too, so I might as well get it off and move on. I kept everything of course since you never know when I'll want to put the car back on it.
First I raised the lift to the level of the car and back it up to the edge of the lift.
Then I put my trans jack where the fuel tank goes:
Then I started taking the rotisserie apart and backing the car over the lift
Then lift the car off the ground with the lift
Old Dec 14, 2014 | 08:53 PM
Car: '91 LS6/T56/9"
Engine: LS6
Old Dec 15, 2014 | 09:00 PM
racerkilla's Avatar
Car: 85 iroc with 92 ground effects
Engine: 355 11.1 world product heads
Transmission: t56
Axle/Gears: 3.54 dana 44
Very nice job.. I just did just about a complete tear down like this.
I like your subframe connectors. I went with jegster bolt in kit and bolted and fully welded them. I did notice that they metal off the back of the connectors that went through the control arm bolt. Might be worth welding a flat piece of metal on the back of each connector so the control bolt goes through your connector.
I see you brushed on the bedlinder. I have had good luck using a shultzs gun at higher pressure with that brand. Comes out textured and very even.
But yea great build. Only way to do them. You know every bolt of the car and what is done.
Old Dec 16, 2014 | 10:57 AM
LC2 TECH's Avatar
Looking good. Make sure if you weld the subframe connectors on while the car is on the rotisserie that there is no body twist in the car.
Old Jan 3, 2015 | 10:28 AM
Car: '91 LS6/T56/9"
Engine: LS6
Yes the rear of the subframe connectors will have 1/8" plate wrapped around the control arm mount. I just haven't gotten that far yet.
I was thinking about what position to mount the connectors in, and I think on the rotisserie will be fine considering the car is literally broken down as far as it possibly could be.
Old Jan 9, 2015 | 08:43 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Nice work...
I cant wait to see how it turns out.. keep us updated
Old Jan 15, 2015 | 05:16 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
look forward to the progress
Old Jan 15, 2015 | 06:44 PM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
What are you gonna do with the 86's body? And sweet rotisserie!
Old Jan 19, 2015 | 12:03 AM
SoTexSwoldier's Avatar
Coming along great! Good Luck!
Old Jan 22, 2015 | 01:55 PM
Car: '91 LS6/T56/9"
Engine: LS6
It will be scrapped. I abandoned work on it because of too many rust issues. Once I get everything off of it I won't need it hanging around.
I hope to sell the rotisserie once I know I'll never need to put the car on it again.
Old Apr 25, 2015 | 09:48 PM
Car: '91 LS6/T56/9"
Engine: LS6
Finally got back to work on the car. Bodywork is fully underway now! Right now I'm finished sanding the engine bay, roof and quarters. One dent to pound out in the passengers quarter, and a small area in the drivers wheel well to cut and replace. I decided to sand down the existing paint and not completely strip everything down to bare metal. Too time consuming and not necessary.
I'm constantly fighting myself on this car. I just don't know how far to go.....Once I think I'm done sanding somewhere I just keep finding more and more and MORE to do! I need to keep reminding myself that this isn't a show car. It's going to be driven and enjoyed and it doesn't need to be perfect. If I keep trying to make things perfect I'll simply never finish it.
Also put the sandblaster to good use:
Somebody previously cut a hole in the drivers battery tray so I finished smoothing it out. Was very jagged before.
Also pull all the weatherstripping and molding off:
Drivers door striker hole is jacked up so I'll have to pound/weld that back into shape:
Old Apr 25, 2015 | 09:57 PM
Car: '91 LS6/T56/9"
Engine: LS6
So as of now:
Fenders, hood, bumpers - coming off of the car in the very first pic of this thread.
Doors - Came got off of a '91 Firebird (not pictured yet) from a Victory Auto Wreckers free parts weekend ($50 as much as you can carry)
Ground FX - Have a pair from a parts yard that need some work. Not sure if I'll use them or find another set.
Paint will go like this:
Grey epoxy primer
Grey high-build primer
White sealer
White paint
Still not sure about black stripes pr accents.....opinions?
Here's where the engine bay is now. Not doing any more sanding on it.
Old Apr 30, 2015 | 09:52 AM
  #42
rwdtech's Avatar
Car: 1991 Z28 (sold)
SUBSCRIBED! Damn, I wish I had a third gen again!
Old May 1, 2015 | 08:03 PM
  #43
Car: '91 LS6/T56/9"
Engine: LS6
Finally pulled the windshield today. NEVER want to do that again! The tool I bought was garbage so I ended up just smashing it out then coming back with a razor and getting as much old sealant off as I could. Then I used a SUPER aggressive wire wheel on my angle grinder.
After all that I'm very happy with the results. No rust, but there were quite a few gnarly places under that windshield sealant in the form of welding slag and sharp metal points near the spot welds. I ground them all down of course. Kinda satisfying.
After coming this far I'm not going to puss out now! I'd like to have to do this only once!
Old May 2, 2015 | 03:26 PM
  #44
Car: '91 LS6/T56/9"
Engine: LS6
Today I sanded the windshield channel since I didn't get to it yesterday.
I also finally tore apart the doors (only got to 1 today) that I got from a parts yard years ago. I'm glad I grabbed them because they're about as clean as a midwest car door could get.
They came from a '90 or '91 Firebird so I'll have to weld 2 or 3 ground effect mounting holes and eventually drill the correct ones.
Since I still need to spray lizard skin on the inside of the doors I decided to gut them. Not very hard at all and since I know what I'm doing now the second door will be very easy.
To remove the glass you have to drill/cut 3 rivets.
This one:
And these 2:
After then the window just pulls out:
And because I'm pulling the glass I'm sure I'll just replace it.
Here's the rest:
Old May 2, 2015 | 11:36 PM
  #45
DynoDave43's Avatar
No rust!
Old May 3, 2015 | 08:24 AM
  #46
Car: '91 LS6/T56/9"
Engine: LS6
No rust!
Well not anymore! What little rust I found on the door was sandblasted off then treated with a rust remover so it'll never come back. Nothing on the doors needed to be cut and patched luckily.
Old May 3, 2015 | 07:17 PM
  #47
Car: '91 LS6/T56/9"
Engine: LS6
I finished up some prep on the first door (Passenger) Popped out the spring and took apart the bottom hinge for sandblasting.
Old May 3, 2015 | 07:18 PM
  #48
Car: '91 LS6/T56/9"
Engine: LS6
And here's the sandblaster I've been using:
Old May 3, 2015 | 07:23 PM
  #49
Car: '91 LS6/T56/9"
Engine: LS6
The drivers door hasn't been touched yet but I looked it over and appears to be in even better shape than the passenger side. I've also been trying how to adjust my Nikon cameras setting to take better pics. Some seem too dark to me.
I also need help..........This has been a one-man project until now. Without some bodywork help it'll simply take too long so and skilled hands feel free to contact me.
My goal is to have the car assembled and painted one month from now.
Old May 3, 2015 | 08:07 PM
  #50
loud91rs's Avatar
Car: 91 Camaro RS 92 Camaro RS
Engine: 406, 305
Transmission: TH350, 700R4
Looking good Rob! If you weren't so far away i'd come by and help you with the body. Keep us posted!
