89 Camaro steering box cracked frame
Hello, I have a question, is it possible to have the front frame rail rebuilt to mount the steering box to the frame or I was told the frame is a 2 piece and I could get a new front frame and have it welded. Here are a few pics, any thought welcome please!
1 Post
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: 89 Camaro steering box cracked frame
That crack is a huge safety issue, have that section of the rail replaced and welded in. Failure will be catastrophic when it lets go. Just my two cents.
The car isn't being driven, we had it towed. We took out the broken steering box. What we aren't sure of is, is it a k member that we would need to replace or when you hear talk of replacing the front clip? We have found a whole front end, I'll add the pic. My friend isn't sure what part I need to get to replace this and fix the problem, without patch welding a piece on.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If everything comes out the way it should you can mount a "steering brace" AKA Wonder Bar to help prevent that.
Link = https://www.thirdgen.org/forums/afte...r-bar-1-a.html
The whole thing had broke off so he just pulled the steering box out as it was leaking. Prior owner had installed a wonder bar but as it seems that was a little to late because it broke completely off the frame. I'm just not sure what we need to buy to fix it if we don't want to fabricate a piece and weld it on......?
Yes, it costs less to buy and install a steering brace (aka wonderbar) than to repair the cracked frame the steering gear box is mounted to.
http://www.top-downsolutions.com/cha...or-firebird-(a
Lon Salgren
Lon Salgren
jdost1992
04-11-2016 12:31 PM
tchapps88
04-05-2016 03:12 PM
