AGR steering box
Old Apr 15, 2016 | 07:14 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
AGR steering box
picked this unit up from another member. stripped it down had it plated. then sent it off the AGR and had them redo it..set to install..
if I'm keeping my power steering..might has get it as tight as I can..would have just rebuilt it my self. they are easy.. but I fould a few trick parts inside. I cound not get in just the GM kit. so off it went...
rust free forever
Old Apr 16, 2016 | 06:31 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: AGR steering box
That is a purty setup.
Old Apr 16, 2016 | 01:43 PM
Thank you... these ARG steering boxes are pretty tricky units.. There are three sets of bearings on the shaft connected to the pitman arm. Instead of just the one provided by Saginaw. Almost 30 ball bearings Inside compared to the 16 in stock units. The parts themselves are just better looking inside. now if we could just get these made with Billet aluminum bodies. We could drop about 11 pounds.
Old Apr 16, 2016 | 02:34 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yes, aluminum bodies would rock for these
Old Apr 17, 2016 | 02:01 AM
mock up hi presh/low presh lines
Old Apr 21, 2016 | 09:24 AM
propaintball96's Avatar
Do you have a build thread? Looks like some really nice stuff going into this car
Old Apr 21, 2016 | 10:41 AM
Size:  91.3 KBwould like to do one from the time I picked it up from GM. To Lingenfelters. To now..
this shot is from 1992/3. The day it came dack from LPE
Old Apr 21, 2016 | 10:56 AM
BADNBLK's Avatar
COTM Editor
I love my AGR box!
Old Apr 29, 2016 | 05:15 PM
CLE_berlinetta's Avatar
Car: 1983 Berlinetta
Engine: 383 Stroker
Transmission: 5 Speed
Axle/Gears: 11:41 3.73
Box looks great! Do you have a link to this base AGR unit? Will it bolt on to an 1983 Berlinetta? Thanks!
Old Apr 29, 2016 | 05:41 PM
Mine's a bit different..
Part #for your car is 225153 $427 summit.
Old Apr 29, 2016 | 08:15 PM
Engine: 383 Stroker
Thank you!
Old Apr 30, 2016 | 03:55 PM
I started with a used AGR box. and had it plated. I then sent it in to have AGR redo it to new.. they test and tune it and ship it back ($235) this includes new billet caps. top and end cap...call and check it out..TURN TIME WAS 3 DAYS it was on it's way back..
pick up a chrome pump.$90..then picked up a March Billet Pump $300. as the upgrades continue.(the march pump is better looking.
in this shot you can see the stripped box. before I sent it back to AGR.
Old May 9, 2016 | 06:02 PM
Engine: 383 Stroker
I ordered and have received the AGR 225153 from Summit. Everything looks a match except for the size of the connection to the pitman arm. The new AGR seems to have a larger diameter to the pitman arm than the stock Saginaw box. I called AGR and they said the Camaro either came with the smaller 605 Saginaw or the larger 800 series. The smaller diameter about 1 1/8" and the larger 1 1/4...
Is anyone familiar with these two types of boxes and more specifically the pitman arms? I would like to just buy the larger diameter pitman arm but it seems AutoZone and Advanced don't carry it. O'Reilly's seems to have the smaller one (no help)... At a glance, no love from Moog either...
Does anyone know if the Irocs or Z28 came stock with the larger boxes? Any casting numbers or links to pitman arms would be a huge help. Thank you!
Old May 14, 2016 | 12:12 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
Where did you send it for plating?
Old May 15, 2016 | 10:48 AM
a place close to me. Novation metal finishing.
boat load of parts to zink plate $70 now.. every time I get some done criss tells me bring more parts get my moneys worth..lol
Old May 15, 2016 | 10:57 AM
I will have a few after getting the car done...
but you can get one off ebay for under $40..
martindforsythe
Apr 30, 2020 04:42 PM
broke91firebird
Sep 2, 2019 10:02 AM
martindforsythe
Apr 10, 2016 03:54 PM
Flybird8488
Mar 30, 2016 12:50 PM
smokingss
Exterior Parts Wanted
Mar 28, 2016 03:35 PM
