Passenger door won't open
So my Camaro has shaved door handles (bought it that way). Only the drivers door has a popper. Passenger door has always had to be opened from the inside. Was cruising around with friends yesterday and when we went to leave we couldn't get the passenger door to open. You can hear the latch mechanism working. Wondering if the door got shut at a bad angle and got jammed. Whats the best course of action I can take?
Car: 1985 trans am
Re: Passenger door won't open
Take the door panel off and see if the anything cam disconnected. No other options that I can see
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
-1 point for shaved door handles! I do not have shaved door handles. I had issues opening/closing the driver's side door. With the door open, my mechanic applied a little lube to the latch mechanisim and...voila! The problem was solved.
Sorry for your woes!
Bill
Bill
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
This sounds really dumb, but perhaps the striker/latch alignment got off. Have you tried having someone on the outside pushing in on the door right around the handle area while someone is on the inside trying to open it? Just a thought?
On Probation
STOP!
No need to try and destroy door panel trying to remove it on a closed door!
Roll down window
Look down into the rear of door at the latch and lock and handle rods
Fashion a rod with a hook on the end
Prob down inside the door and both move the lock rod
then the latch rod
Open the door!
Roll down window
then the latch rod
Open the door!
It can probably be done with the door closed, it's just going to be a lot harder, and you're probably going to break most of the clips, but they're cheap and readily available. I've done it before on a B-Body car without destroying the door panel, and I think I was only maybe 16 at the time, so chances are I wasn't the most careful with it either. In my case, one of the nylon latch rod clips had broken, and the latch rod got jammed in the latch. I remember fixing it with a twist tie from a loaf of bread as I had not yet been introduced to zip ties at the time.
STOP!
Roll down window
then the latch rod
Open the door!
Roll down window
then the latch rod
Open the door!
On Probation
YUP!
No prob.................
Its EASY doing it the RIGHT WAY instead of destroying the
doorpanel.................
Eric-86sc
04-03-2016 09:56 PM
