What if you don't bench bleed?
Old 04-12-2010, 09:55 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
In redoing/modifying my brakes I forgot to bench bleed, this was of course after I removed the master cylinder and prop valve. I have been trying to bleed them now for almost a full day. I'm just starting to get a little pedal. So I'm assuming I can get bleed the brakes without bench bleeding. If so anyone have a estimate on how long it will take.
Old 04-13-2010, 06:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: What if you don't bench bleed?
Because of the angle at which the master sits (and air rises), your chances of a successful bleed is probably non-existent. Some members have tried lifting the rear end in order to level the master.
JamesC
Old 04-13-2010, 01:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i dont have the paper handy, but there is a way to bleed the master with it on the car. You have to make lines that go from the 2 outlet ports and loop up and back into the master reservoir, below fluid level. Then pump away untill the bubbles stop. Not sure if there is something else involved, i just remember this method, or something similar, from the instruction sheet that came with a new master i bought.
or like james mentioned, you can try to raise the rear of the car to level the master.
Old 04-13-2010, 02:33 PM
JamesC's Avatar
Light bulb. The above may be available as a kit. Still, I'd think the master would have to be level. Here's the idea:
http://www.superchevy.com/technical/...nch/index.html
Maybe a power bleeder.
http://www.jegs.com/i/Motive-Product...0105/10002/-1#
The application guide lists thirdgens to 91 (why not 92?)
JamesC
Old 04-13-2010, 04:23 PM
Car: 1988 IROC-Z28
Thanks guys for the info!
backtothe80s
09-05-2015 12:39 AM
Bubbajones_ya
08-28-2015 02:17 AM
wayshegoes
08-17-2015 12:00 PM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Quick Reply: What if you don't bench bleed?
