My Baer 14" 6S front brake upgrade.
Old 09-24-2015, 02:42 PM
COTM Editor
BADNBLK's Avatar
I have been meaning to make a thread in here about the brake upgrade I put together over the spring.
I bought these front brake caliper, brackets, and rotors from a member here used from a project that changed direction. I already had a Baer track plus set up with polished two piston PBR calipers and two piece 13" rotors, so the upgrade to the Baer 6S mono-block caliper and two piece 14" front rotor was a pretty easy project.
So easy to bolt together, but I'm kinda a stickler on the details and I couldn't have that yellowed looking clear anodize up front with the polished rear calipers so this is where the project, became more of a project than just hanging parts...
I stripped the 6S Calipers down for polishing
So the aircraft stripper removed the baked on paint recessed in the Baer script, but doesn't touch the anodizing on the billet aluminum. So the next step:
Oven cleaner! Oven cleaner will remove anodizing, but its a tricky process to remove it without it etching the aluminum below.
Top is stripped, and bottom still anodized
Starting the polishing process
Close up, but still not good enough
Here is where I inlayed my teal paint into the Baer logo and script.
Old 09-24-2015, 02:50 PM
COTM Editor
BADNBLK's Avatar
Re: My Baer 14" 6S front brake upgrade.
Here is the final finished product. I'm totally stoked with how they turned out. Baer no longer offered a polished caliper option, so I can say that these are the only ones out there!
The old rotors sitting over the top of the new ones for size comparison.
Peeking out from inside my 18" wheels.
Hope you enjoyed!
Old 09-24-2015, 04:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
That all came together very nicely! Very nice work with the polishing.
Old 09-24-2015, 05:44 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
That's some purdy right there!
Originally Posted by BADNBLK
Old 09-24-2015, 07:11 PM
Justin69's Avatar
Car: 89 Camaro RS
Engine: LT1 w/ 70mm Turbo
Transmission: Stage 3 TR6060
Axle/Gears: 4:10
Very Nice!
Old 09-24-2015, 08:42 PM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Nicely done!
Front and rear width & offset of the ROH setup?
Old 09-25-2015, 01:54 PM
COTM Editor
BADNBLK's Avatar
It really did! Thanks again for changing directions with yours so I could get these. Turns out I like polishing stuff lol
Dang right!
Originally Posted by Justin69
Very Nice!
Thank you!
Originally Posted by jmd
Nicely done!
Thank you! I honestly don't remember back spacing specs and such. Been over 10 years since I bought these. 18x9 and 18x10 is really all I can tell you without pulling them off and measuring. Make me an offer on them and maybe I'll just sell these to you
Old 09-29-2015, 10:45 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Looks great buddy
Old 09-30-2015, 10:42 AM
COTM Editor
BADNBLK's Avatar
Originally Posted by morrow
Looks great buddy
Thank you sir!
Old 10-04-2015, 11:40 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
That looks awesome ... I'd be interested to know how it goes with upkeep/polishing down the road
Old 10-06-2015, 11:02 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
I'd be interested in getting the details on the hub/spindle/bracketry for this setup up. I see you had an existing Baer kit already, is that off the shelf stuff or proprietary from Baer?
edit: Really looks good too.
Old 10-06-2015, 02:51 PM
COTM Editor
BADNBLK's Avatar
Well I expect that the upkeep will be about that same as the old set up see how they were both polished. My original track+ kit I have had since 2005, and have only seriously polished them one time. But basically any polishing I do is hand polishing through the wheels, and that has worked well enough to still bring home some 1st place trophies in shows.
I can say that I had a rock? jump up between the caliper and the wheel, and leave a nice scratch on the inside of the wheel.
Not much details for me to provide. The original kit I used was from Baer and they supplied, everything... spindles, hubs, bearings, fastners, hoses etc. I can say that we took all my old stuff and my best friend made his own kit to install that on his 89 IROC. Modified the spindle, made adapters, and cut down the rotors for hubs on his.
Ed1LE
09-30-2018 09:14 AM
Scorched1984
Wheels and Tires
66
04-16-2016 06:56 PM
84 TA NV
09-06-2015 08:02 PM
Todd91SS
Aftermarket Product Review
11-22-2001 07:04 PM
Colt
11-06-2000 09:00 PM
Quick Reply: My Baer 14" 6S front brake upgrade.
