New stock disc brake calipers
Old 09-27-2016, 03:47 AM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hi everyone,
I'm converting my car to rear stock factory discs over the drum brakes. I have to go stock disc because I have 14" rims so I can't put on anything bigger, and I know stock calipers do fit inside a 14" rim. Buying bigger wheels is an expensive option so not going to happen.
I know that 82-86 (or thereabouts) calipers had a kit you could buy which fixed a problem where the e-brake didn't work very well. My question is, if I go and buy remanufactured calipers will they have the fix applied to them or will I still have to get hold of the overhaul kit from somewhere?
Thanks,
Old 09-27-2016, 01:46 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: New stock disc brake calipers
I am not sure about the ebrake kit but my remanufactured calipers from advance auto have never given me an ebrake issue it holds tight all year every year. Also I think the drum axles had a different hub diameter that does not fit in the factory rotors.
Old 09-28-2016, 02:53 PM
Car: 1989 Trans Am
Thanks for that, makes me feel more confident in getting re-manufactured calipers now. These are going onto a diff that already has disc axles so I should be good there.
Old 09-28-2016, 02:59 PM
midias's Avatar
These are the same as what I run. Still no idea if they have the kit but my ebrake works
https://www.summitracing.com/parts/a...4164/overview/
Old 09-28-2016, 10:37 PM
Car: 1989 Trans Am
Thanks for the link.
Old 09-29-2016, 06:54 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Your store bought calipers are unlikely to have the recall kit installed. May or may not still be available:
Part Number: 18019028 from GM Parts Direct, listed as "Actuator" and included parts for both rear calipers, pistons, springs, seals, etc.
Old 09-29-2016, 05:50 PM
Car: 1989 Trans Am
Thanks for the part number. To avoid returns on the product, wouldn't they want to have the recall kit already applied to re-manufactured calipers?
oil pan 4
09-10-2016 08:09 AM
wolf454
Brakes
08-29-2016 05:07 PM
Bald_eagle_machine
08-27-2016 10:24 PM
Zylinder
08-24-2016 04:15 PM
87RockTPI
08-21-2016 11:33 PM
Quick Reply: New stock disc brake calipers
