89 Iroc project car WV
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Clean title, Motor is shot. Includes a 700r4 trans that works with a torquemaster converter. It has a 86 posi disc rear with 4:10 gears. It comes with the Iroc wheels with good tires. Some of the wiring needs fixed. I started to part it but didn't finish. A new Cervinis hood can be included. The interior needs work. I sold the speedo cluster. The body is fine. It was wrecked when I got it. I replaced the whole front bumper assembly/cover. The core support is dent slightly. It's hardly noticable. I have a ton of parts to include with it if needed.
I am looking for $1k for it with the hood, 600 without. Someone could have this car running and on the road quick if they put the time into it.
Pics can be posted later if anyone is interested. I am in Lesage, WV.
Transmission: A4
Axle/Gears: 3:23
Re: 89 Iroc project car WV
Like I said the motor isn't that good. I poured oil in the bored and got it turning. It just sit for awhile without the heads. I don't feel like pulling the motor and don't consider it part of the cost of the car.
I would include new headers, drivers t-top seal, 28 spline posi and superior axles, t bar and quite a few other parts. It comes with a non ac box and all the serpentine stuff too. I easily have 1k in just the little parts alone.
I've started working on the car and might just get it on the road but if I get a offer for everything, I'll let it go.
In the pics, it has z28 wheels on the front. I have the front Irocs to include. They were just low on air so I put the others on there.
Transmission: A4
Axle/Gears: 3:23
Like I said above. It needs work. It has no rear seats or passenger seat. Headliner is gone too.
Transmission: A4
Axle/Gears: 3:23
I have a few buyers lined up for the hood if I do decide to sell it. At the present, I am probably just going to keep the car in one piece and start putting it back together. I can't seem to move the parts or the car so I am probably just going to do my best to get it back on the road. Maybe it will sell easier that way. Frustrating, it really is.
Transmission: A4
Axle/Gears: 3:23
Still trying to sell this thing. I'll try to describe it as much as possible with more details this time.
It was a running car a few years back until I tore it down to port the heads. I didn't get it back together. Here's what it has included. The tpi system is gone except for the powdercoated plenum, fuel rails and throttle body.
89 Iroc-Z originally a 350 car with a 9 bolt rear. Not sure of the miles. I think 127k before I sold the cluster.
1984 Reman 305 shortblock .060 over. Has some rust in the bores I don't know if the motor is still good, may just need a freshening up. It only had 15k on it.
Summit 214/224 cam
Heads done by performance chevy in AZ 53cc 601 castings. 1.94/1.50 manley valves, screw in guide plates, .510 lift springs. I ported them some more. They have a slight crack around the temp sending unit. I ran it like that with a dab of jb weld and it held fine.
Crane 1:6 rockers, hardened pushrods
Tpi distrubuter, air inlet, serpentine system. March crank underdrive pulley
Trans is a 89 700r4 with a shift kit and B & M torkmaster 2400 stall converter. It worked ok. Slight delay from 2nd to 3rd. (still better than my 01 Z28's shifts)
Rear end is a 86 posi disc with 4:10 gears. I also have lakewood lower control arms on back.
Spare parts included are Headman headers and y-pipe. Never ran on car. The one header has some dents near the collector. Nothing that will stop flow.
Ac delete air box and controls, a better t-top bar, 28 spline posi unit and superior axles for the rear.
It has the factory exhaust with a afterburner muffler.
The interior is missing the rear seats, passenger seat, headliner and the instrument cluster.
It comes with a B & M megashifter that's currently out of the car. You may need to buy a new cable.
3 gauge pod, perfect dash cover. It includes 4 Iroc wheels that need finished. All have good tires. I have Z28s on the front for now because the others lost air from sitting.
That's about all I can think of. The body is mostly rust free. It has a little on the rear wheelwell lips. Not bad. . The front was hit at one time before I got it. I replaced the bumper, cover and passenger fender. It needs a factory fender because it does not fit right.
The hood is a Cervinis. Never finished. I paid $ 579 shipped for this thing!
Anyhow, Let me know if you're interested in the car and everything included. I don't want to part if I can help it. This would make a great project or a parts car for whatever you currently have. I was going to carb it and make it a race car but I am running out of time searching for a house and I need this gone.
I was asking $1000 on here and Craiglists. I will take any offers. I will consider sellling parts if I can't get anyone to buy it whole.
Email is sweetemotion315@yahoo.com
Summit 214/224 cam
mustangman65_79
08-11-2015 03:17 PM
