Fuse location for orange constant 12 volt supply to radio/tape
Old 12-12-2013, 04:23 PM
pirtekman's Avatar
Hi all,I accidentaly touched the orange12volt constant supply wire to radio and there is now no power in this wire.where is the fuse located to fix my problem.Thanks Alan.
Old 12-12-2013, 05:29 PM
*84TA's Avatar
Car: 84 Trans Am
Re: Fuse location for orange constant 12 volt supply to radio/tape
Under the dash. Not sure which one. I would just pop them out till you find the bad one.
Old 12-12-2013, 06:09 PM
Joe Tag's Avatar
Should be the "ctsy" fuse.
Old 12-12-2013, 11:43 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I would check the fuse labeled RADIO
Old 12-12-2013, 11:50 PM
Joe Tag's Avatar
You'd think that wouldn't you? He did say the constant hot wire which also has dome and cigar lighter on that circuit. That's why I posted the wiring diagram too. The radio fuse is just the ignition power to it, not the constant hot.
Old 12-13-2013, 01:15 AM
pirtekman's Avatar
Thanks for the info.The interior light(dome in middle of roof is still working)On a visual inspection of the fuses they all look to be good.
Old 12-24-2013, 11:03 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
The fuse for the constant 12 volts is located in the convenience center. There is another fuse box to the right of the steering column. The fuse is in there.
Old 01-17-2014, 05:05 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Axle/Gears: 9 Bolt - 3:45
For 12 years I've been running a separate constant power wire and then I see this post...... I literally ran out to the car, ripped off the cover panel, found the secondary fuse panel and sure enough, blown fuse.
Old 01-19-2014, 09:18 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Always learning something new on TGO.
Nick McCardle
09-10-2015 08:36 PM
Glowsock
09-06-2015 06:40 AM
luvofjah
09-03-2015 07:08 PM
tonys91rs
09-02-2015 07:07 PM
Quick Reply: Fuse location for orange constant 12 volt supply to radio/tape
