86 Iroc needs bump
Car: 86 Iroc-Z
86 Iroc needs bump
Soo... finishing up a beautiful resto on my 86 iroc(pics coming soon)... looking for info on A/M audio, my weakness in cars lol... I'm looking to amplify my rear speakers and a pair of subs.... will a 4 channel amp do the trick for this? or am i better off running 2 separate amps? I'm not a real stickler for sound quality and just looking to add a little bass... any and all input is greatly appreciated!
1 Post
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: 86 Iroc needs bump
agree with that, or a fairly easy way to add a little bit would be one of those package, sub tubes with the amp integrated.
1 Post
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
The only issue with third gens are that the rear speakers face each other, canceling bass response. You can add an amp and wire one speaker out of phase from the other. This will add more response. Also add a baffle behind the speaker if you can.
Note: This doesn't work on all cars for some reason, but will work on most.
mustangman65_79
08-11-2015 03:17 PM
