Problem with stock carb???
Old 04-15-2002, 01:57 PM
Tbird's Avatar
I have a 87 with 305 and 4bbl carb, When I get on it soemtimes i can tell that all 4 barrels open, but other times when i get on it it doesnt sound like it does not as deep of sound and it seems slower anyone else have a problem like this letme know thanks...
Old 04-15-2002, 06:50 PM
smallblockFBird's Avatar
the jets may be wrong
you may have incorrect jets for the climate your in (flooding the motor). I really dont know though.
Old 04-17-2002, 10:56 PM
1986redbird's Avatar
when exactly do you notice this problem (any specific time, when the engine is just started or when it is hot), there is a secondary lockout to prevent them from opening when the motor is not heated up all the way.
Old 04-17-2002, 11:23 PM
Tbird's Avatar
the problem accurs when i first start it and drive it but if i get it hot then turn it off then back on like 5m inutes later then it works any ideas how to fix???
Old 04-19-2002, 01:51 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The carb is designed to keep the secondaries from opening until the choke is completely warmed up and open (off).
If it is holding the secondaries closed even when warmed up, you may need a linkage cleaning or adjustment. The little catch can be a little too close to the lock-out pin and keep them from opening even when they should.
Infested
05-22-2018 11:56 PM
84z96L31vortec
08-20-2017 12:16 AM
Azrael91966669
25
06-20-2017 04:04 AM
theshackle
03-05-2017 06:37 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: Problem with stock carb???
