Car stalls under heavy cornering/ braking
Old 05-29-2001, 10:19 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I run a holly 650 Double pumper spreadbore. If I brake/ corner too hard the car will stall on me. A lack of fuel is causing this. What is wrong with my carb an how do I fix it? Somebody told me it's the float level.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.32@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake, ported heads.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box, gutted cat.
Old 05-30-2001, 07:53 AM
82camaro's Avatar
Car: 82 camaro SC
I would try float level first.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old 05-30-2001, 10:03 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
how do I adjust float level?
1986 CAMARO Z28 ->
1987 TRANS AM ->
Old 06-03-2001, 02:12 AM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
my car does the same only when I corner real hard, but I have TPI. I think we need a swinging fuel pick up in the tank.
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
Old 06-04-2001, 10:26 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I checked for the adjuster on the front bowl, mine doesn't have one. what does that mean? Do I have to take off the front bowl?
1986 CAMARO Z28 ->
1987 TRANS AM ->
Wade787b
09-29-2015 01:15 PM
AkDrifted
08-17-2015 07:45 PM
TreDeClaw
08-14-2015 06:58 PM
Ginamariegault
Brakes
08-10-2015 08:33 AM
MENINBLK
08-05-2015 11:58 PM
Quick Reply: Car stalls under heavy cornering/ braking
