600 hp 350?
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: automatic
600 hp 350?
is it possible to build a 600 horse normally aspirated 350? mine is a 4bolt main, 4bbl and i want to tear apert my friends 320 TT Supra. Anyone now what parts i need ?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is very hard to make a streetable 600hp NA 350. You will either need to stroke it or add some sort of power adder to get that kind of number. I will move this to the carb section for you but they may choose to lock it since your motives are a bit scewed.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Look for a thread titled something like "lets talk about 500 hp N/A builds" or something like that. you will see that while high hp engines ARE possible out of a 350, you lose pretty much all street manners.
You want a 600 hp N/A? Go build an SB2.
I have seen what TT Supras can do. you wont beat him without a power adder, biger cubes, etc.
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
possible? well of course everything is
streetable? i'd put my money on no
likely? if you got pockets deep enough
if i were you i'd go with either a BBC or a 383 stroker and try something from there, but without a power adder or lots of cubes 600 hp is a tough number to get to. and if you get to 400 or 500 and aren't happy just strap on some giggle gas and call it a day.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Getting above 500hp in a 350 is going to take some exotic parts - not to mention precise machine work so the puppy stays together at 7500rpm. It would be a lot smarter to build a bulletproof 400hp 350 and then add 200hp nitrous. It would also be a lot cheaper and 100% streetable.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
My uncle was a state legislator. That doesn't mean I knew what was passed into law.
"600 HP NA 350" and "streetable" don't belong in the same sentence.
Car: 1983 Camaro Sport Coupe
Engine: 355
Transmission: TH350
Axle/Gears: 3.08
i'm not here to argue, its the not the point of the board, but I will believe my uncle who helps build Nascar truck racing engines for a living over anyone here who wants to challenge the HP rating they make
Re: 600 hp 350?
10.5:1 cr Forged 18Degree flat top pistons.
Brodix 18X heads with full preparation.
950+cfm holley competition carb.
18 degree single plane intake ( brodix etc)
Comp Cams custom solid roller cam
Grind Number CS304R-8 /312R-8 SR13
272-284 @.050 .700+ lift w/1.6 roller rockers 113LSA
Complete matching Comp cams valvetrain.
Custom made 1-7/8" headers. dual 4"+ exhaust.
The power band will be from 5000 rpm to 8500rpm
use a 5500stall converter . (8")
You'll need a fully prepared race th350 or power-glide and a ford 9" or 12bolt chevy rear (5.13 gears) to stand up to this one.
MSD 7 Al ignition
It's going to be loud.
www.brodix.com
Re: Re: 600 hp 350?
Originally posted by F-BIRD'88
350 forged bottom end
MSD 7 Al ignition
www.brodix.com
MSD 7 Al ignition
www.brodix.com
Car: 1985 Firebird
Engine: 327
Transmission: TH350
I have to agree with the "unstreetable" claim. I am getting almost 600 out of my 327 (12.5:1 pistons), there is no muffler that will quiet it and it is a pain to try to drive it anything under like 60 mph. I have now gone to 5:60 gears with a 5000 stall converter...maybe this will help the thing drive down a residential street.
Upside is that it can be done and it sure gets attention!
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
As the quote goes "Whats the similarities between a 500HP supra and a 1200HP supra? --- THEY BOTH RUN 12s"
Chances are this 600HP supra is just a dyno queen like most other supras.
toronto formula
09-10-2015 07:31 AM
Billy Decker
09-04-2015 03:46 PM
