Replacing fuel line
Old 01-25-2011, 06:51 AM
someone78's Avatar
Car: 92 Camaro
Engine: 400
Axle/Gears: Moser 12 bolt/4.11
Replacing fuel line
Has anyone replaced their entire fuel line? If so where did you route it? By replace I 'm talking more along the lines of removing factory line and running new (aftermarket) larger lines. Thanks
Old 01-25-2011, 07:09 AM
chefman45887's Avatar
Car: 89 Camaro RS
Engine: 283 SBC
Re: Post Your Carb'd Motor Pics
are you going to be running a mechanical or electric fuel pump? that wll chance your front run a little. when i did mine i ran aluminum with the earls fittings took about 2 hours.
Old 01-25-2011, 07:22 AM
430Camaro's Avatar
Car: '91 Trans Am GTA / '83 Camaro
Engine: 383 SBC / 430 Buick BB
Transmission: Tremec TR-3550 / TH-400
Axle/Gears: Stock 10-bolt, 3.42 /10-bolt
I changed my lines as well. I'm running an external electric fuel pump and a reglator. I ran 1/2" steel line from the tank and basically followed the same route as the original lines up around the frame rail and under the brake booster, etc. I flared the ends with 37 deg flares and used 37 deg fittings. I originally used the stock 3/8" EFI supply line as the return from the regulator but ended up needing a second 3/8" steel line for a return to keep the pressures from rising too high and tied the second one into the original 5/16" line at the tank. They all come into the engine compartment at the same location as the stock EFI lines.
You can see them here before I ran the second 3/8" line. http://www.turbocamaroproject.com/GT...EngineBay.html
Old 01-25-2011, 10:06 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
ive replaced my fuel lines with -8an stainless steel braided lines. I had to modify it all to fit dual walbro pumps in my tank. I have -8an for feed and return. If you go look on my turbo thread you will find the pictures you are looking for.
Old 01-25-2011, 10:36 AM
someone78's Avatar
Car: 92 Camaro
Engine: 400
I have walbro in-tank pump. Tied into factory pick ups with -6AN supply and return. To try to hide the lines I went all the way in front of the radiator to get to the other side of the car. My problem is when hot pressure is unstable and it doesn't want to start. I kind of think I'm cooking the fuel.
Old 01-25-2011, 10:40 AM
someone78's Avatar
Car: 92 Camaro
Engine: 400
Looks good. Did you modify the pick up at all to change the size of the supply lines? If so, how? Please check out my response to someone else above to get an idea what my problem is. Thanks
Old 01-25-2011, 12:29 PM
im not really understanding your problem but i pretty much used stock style everything with just new parts and two of each check this thread out that maybe some pics will help you see what i mean
https://www.thirdgen.org/forums/fabr...al-walbro.html
Old 01-25-2011, 12:40 PM
1bad71's Avatar
Car: 91 camaro z28
Transmission: turbo 400
Axle/Gears: 9/bolt
i just went old school, and welded a sump in the tank. then went -8 to the carb.
Old 01-25-2011, 08:33 PM
someone78's Avatar
Car: 92 Camaro
Engine: 400
I understand what you did now. Thanks. It has been recommended to me to run a second return line. It's been a couple years and I really don't remember what I did with the evap line. Man, I really don't feel like dropping the tank again.
Old 01-25-2011, 10:07 PM
yeah i know what you mean, i have to drop mine since my fuel level sending unit went bad, ive been procastinating this and fill up everyother day since i dont know how much fuel i have left. its just time consuming.
Old 01-26-2011, 01:21 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I moved this question and the responses to a new thread because it didn't have anything to do with posting pictures of your carb'd set-up.
Frozer!!!
01-19-2024 04:55 PM
specialized
06-18-2022 09:26 AM
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
MustangEater82
Brakes
08-11-2015 07:52 AM
Quick Reply: Replacing fuel line
