cfi wiring???
Old 05-06-2012, 08:37 PM
jmuehler's Avatar
Car: 1982 Z28
Engine: 355
Transmission: th350
Axle/Gears: factory 7.5, 4.11s
cfi wiring???
Ive recently swapped my 82 z28 crossfire injection to a regular 4bbl with a mechanical fuel pump. now I need to know what wiring i can eliminate. could use any help i can get.
thank you
Old 05-07-2012, 04:10 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You can eliminate all of the wiring that is part of the bundle that goes to the passenger side wheel well. I wouldn't recommend cutting it, though, as it can all be removed intact.
If you have an automatic transmission, you should do something to hook up the torque converter clutch lock-up. There are kits available, or you can rig it up yourself if you like (there is a tech article on it linked from the TGO homepage).
Also, if you haven't done so already, you need to drop the tank and remove the in-tank electric pump (unless you power it to feed the mechanical pump, and use a return regulator to control fuel pressure). There is a sticky in the top section of this forum that describes how to convert an in-tank electric pump pickup to mechanical.
Old 05-07-2012, 10:29 PM
jmuehler's Avatar
Car: 1982 Z28
Engine: 355
Transmission: th350
Re: cfi wiring???
would my 3 speed auto have a lock up tho?
Old 05-07-2012, 11:19 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: cfi wiring???
if it's the original th200c it will have the lockup.
Old 05-08-2012, 10:55 AM
jmuehler's Avatar
Car: 1982 Z28
Engine: 355
Transmission: th350
Re: cfi wiring???
Alright ill look into that some more. Thanks for the help
Glowsock
01-09-2017 04:06 PM
Caspar
06-19-2016 11:19 PM
ndndndnd
Carburetors
17
09-05-2015 06:24 PM
Bryan F
08-27-2015 07:28 AM
Bert87
08-23-2015 03:50 PM
Quick Reply: cfi wiring???
