Will this fit under my hood???
Old May 4, 2012 | 11:15 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
I'm going to the Edeljunk Vic Jr w/ a edeljunk 750 carb... will this set up fit under a stock hood?
Old May 4, 2012 | 01:11 PM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
Re: Will this fit under my hood???
yes but you wont be able to run an air cleaner, i couldnt get the hood to close with one
maybe if its a low profile one though..
Old May 4, 2012 | 01:28 PM
Car: 1988 Iroc-Z
I wonder if you could use one of those carb hats w/ a "cold air" intake style system...
Old May 4, 2012 | 01:33 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
most of the carb hats are like 3 inches tall, thats taller than a regular air cleaner
Old May 4, 2012 | 01:38 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
what about 2" filter w/ drop base?
Old May 4, 2012 | 02:04 PM
Car: 1988 Iroc-Z
I was thinking of the drop base too... The only problem I see w/ that is the throttle linkage might get in the way...
Old May 4, 2012 | 02:50 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
i just dont run one, mine isnt a daily driver so im not worried about it.
you could always use one of those super thin ones that are like an inch tall. but i always thought they would hurt airflow due to how small they were like 6 or 8" diameter if that
Old May 5, 2012 | 09:01 AM
Car: 1988 Iroc-Z
I think K&N makes a small one but not 100% on it... Mine will be a DD and I unfortunately have to take dirt roads on occasion... Ahh the joys of livin in Bama son lol... I've got a few of the drop base air cleaners so imma try that and see how she blows (or sucks, ur choice)... When I get it on the dyno, I'll post up the difference between air filter and no air filter just bc now I'm curious to how it will actually proform
Old May 5, 2012 | 09:47 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
You could probably use an air filter for a boat to keep the big stuff out.
Old May 7, 2012 | 01:01 PM
Car: 1988 Iroc-Z
I didnt think about that... and I can put a foam filter around it... I'll pull the one off of my dads 383 in his boat to see what kind of clearance there is!
Old May 7, 2012 | 02:36 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
I've got a drop base on mine dude. Exacty the same setup. Not sure if that vic jr is taller the my rpm air gap or not...we could measure.
As mine sits, it rubs ever so slightly on the nuts for the louvers.
Old May 9, 2012 | 03:54 PM
Nathon's Avatar
Car: 91RS, 97hoooonda, 83sc
Engine: Carb 5.7,Tpi 5.7
Axle/Gears: 93TA rear lsd 3.23
i believe the edelbrock foam triangle ones are relatively low profile with alot of surface area. not the best filter ever, but better than nothing. heres a link to what im talking about.
http://www.autopartswarehouse.com/sk...pw1002aiclased
Old May 9, 2012 | 04:12 PM
Tried one. Far to tall. They are taller then the Spectra filter I run now.
Old May 9, 2012 | 04:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Nothing might be better, actually.
Why not just get a cowl hood?
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Wvcamaro
Sep 4, 2015 08:38 PM
cougar20th
Aug 27, 2015 08:04 AM
