Engine start issue
Old 08-06-2013, 05:53 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Engine start issue
A normal start should be turning the key without pumping the pedal. For some reason fuel is not staying up to the carb (can see it drain from the clear fuel filter about 5 minutes after shutdown) I can pump the pedal and she will start back up but would like to see it crank just with turn of the key. Any ideas why fuel is draining away from carb? I deleted the vapor line and have a filter on the end of hose there at the tank and I thought that might be why so I bent that hose and zip tied it but that didn't do anything.
Old 08-09-2013, 05:16 AM
Re: Engine start issue
Bump
Old 08-09-2013, 05:08 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
Originally Posted by Sidethumper
Bump
The fuel drains out of carbs via gravity eventually however the bowls should remain full for a few days at least.
Old 08-09-2013, 05:34 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
does your gas cap hold pressure?
might need a vented cap?
Frozer!!!
01-19-2024 04:55 PM
Wade787b
09-29-2015 01:15 PM
bradleydeanuhl
08-12-2015 11:48 AM
mizz0313
08-12-2015 06:45 AM
86Base
08-08-2015 01:34 PM
Quick Reply: Engine start issue
