possible value of this Camaro
Old 08-18-2015, 06:49 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
I am thinking of buying this Camaro. It's a little rough but has lots of possibilities. Paint doesn't look as good as photo shows. The guy wants 3100.00 but I think it can be bought for 2500.00. It's a 91 z28. May also just buy to flip. Would like opinions.
Old 08-18-2015, 06:59 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Re: possible value of this Camaro
It needs paint and at least a drivers seat, check on the rust and the mileage. And it needs a dash pad which we all know is expensive. I wouldn't pay more than 2 grand for it, but the fact that it is an automatic I think makes it worth less.
Old 08-18-2015, 07:07 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
122k mileage and no rust at all.
Old 08-18-2015, 08:41 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Anywhere from the 2500-3100 is a great deal.
Old 08-19-2015, 12:01 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
I'd be ALL over it
Old 08-19-2015, 04:53 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
How does the top work? Seals, top itself in good shape? I've never seen a convertible that was cheap to repair. I'm no expert, but for me that would be a bit of a deal breaker. Everything else is cosmetic lol buy a seat and dash cover if it bugs you too much. I think if top is in good shape, and of course it runs and shifts well, 2500-3000 is fair.
Old 08-19-2015, 05:49 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Add up what the work will cost you and then look at what you could buy for that amount - you may find that the dollars get you a lower mileage car that you don't need to do anything to & in the long run will be worth more.
Around here paint work & detailing is easier for me to source than interior work & the original interiors are VERY hard to find in nice condition. Mechanical is usually easy if there isn't anything significant involved. If it's been sitting for a long time expect to do injectors, ignition module & maybe coil.
That one looks like it needs seats, carpeting, dash pad, rear side panels, paint, windshield & I would expect door gaskets and likely a top. With decent Z28 or IROC convertibles still available everywhere for less than 10k, I think you would be under water on that car pretty quickly.
Old 08-19-2015, 08:04 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Thanks guys. I appreciate your opinions.
Old 08-20-2015, 08:25 AM
COTM Editor
BADNBLK's Avatar
Haha! I bought that car last night. Didn't even see this thread until I was coming in here to check a part on how I did something with my last convertible.
Sorry Porkenstein. He took $1800 for it, so I'm feeling even better after reading all the comments for encouragement at $2500.
Old 08-20-2015, 10:02 AM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
No problem. I had decided not to buy it. It was a good deal depending on what you wanted to do with it. At 1800.00 it would be worth restoring. I just wanted a quick flip and at 1800.00 it would be a real good flip on eBay. Glad you got it. The fact that it was a convertible makes it a great deal.
Old 08-20-2015, 10:24 AM
COTM Editor
BADNBLK's Avatar
Yeah I plan on flipping it too. The paint is a little rougher than I would like, but most of the interior and trim parts I need I have in the garage left over from previous build stuff, so should make it happen pretty easy. I thought it was crazy to pop in here this morning and find a post about the car I just bought. GREAT MINDS right!
Old 08-20-2015, 10:58 AM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
(edit) Burb, just read top few reply's. Pay no attention to the man behind the curtain.
I would make 100% sure there is no floor pan rust.
Old 08-20-2015, 11:47 AM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
I can't believe what great deals you can also get on 4th gens, even the convertibles. Even if you buy a v6 they make great projects for an ls motor.
Old 08-20-2015, 03:39 PM
COTM Editor
BADNBLK's Avatar
Yeah I checked. We are all good! CO cars rarely have rust, but I did check.
agreed!
Old 08-23-2015, 05:03 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have perfect condition front grey leather/ vinyl power seats if you're interested.
Old 08-31-2015, 12:54 PM
COTM Editor
BADNBLK's Avatar
I'm not. I got the correct grey cloth seats left over from my 92 RS. I should be good in the interior.
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
84z96L31vortec
08-20-2017 12:16 AM
BADNBLK
11-16-2016 09:12 AM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: possible value of this Camaro
