Hard-wiring cooling fan w/ ignition
Old 05-30-2003, 11:28 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I am just one of those people that can't stand to see the temp gauge above 1/2...
Being that, I would like to hard wire one of my two fans to run constantly with the ignition on. I know which one is which, so that's not an issue....
My question is - Can anyone tell me which would be the correct wire to splice into for power? Got a pic?
Thanks.
I'm replacing the water pump tomorrow, hopefully, and I want to get this cooling system in shape.
Old 05-31-2003, 11:20 AM
MdFormula350's Avatar
if u want to go alittle cooler i would put in a 180 stat, and i wouldnt recommend running the fan all the time. maybe just wire in a manual switch so u can turn it on or off when needed..
Attached Thumbnails Hard-wiring cooling fan w/ ignition-fandiag.jpg
you most likely should wire the manual switch to the passengers fan like it did..
Attached Thumbnails Hard-wiring cooling fan w/ ignition-fanrelaydiag.jpg
Hotrodboba400
12-10-2019 07:07 PM
gta892000
08-11-2019 11:16 AM
Johnoooooo
09-22-2015 08:55 AM
Hotrodboba400
09-02-2015 07:28 PM
Bryan F
08-18-2015 02:28 PM
Quick Reply: Hard-wiring cooling fan w/ ignition
