Upper radiator hose part number for tbi
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Im looking for the correct upper radiator hose for a 89 firebird with a 5.0 tbi every parts store i go to they keep giving me a hose that is to damn long (i was told the tbi hose can be used with the hsr setup) if this matters
Received 1,672 Likes
Re: Upper radiator hose part number for tbi
A lot of hoses, they make em kinda universal, and you're SUPPOSED TO cut em to fit. Lots of em, they provide marks; for this car cut at C, this one cut at E, etc.
What would happen if you cut it?
1 Post
If i cut it, it wont fit over the t stat housing so im not gonna take that route not losing out on 17 dollars for a hose i would rather return this one and actually get the right one for it
1 Post
The end of the hose that goes over the t stat is fatter then the rest of it
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I like this brand of hose and just bought one. Hopefully I wont have the problem you mentioned.
= http://www.autozone.com/cooling-heat...8_16004_10495/
1 Post
Engine: TBI,5.0
That's the same number I come up with for all searches I've done so far. See if you can find a Gats brand. That's what I'm using now.
Its also listed as #21675
Napa Autoparts = http://www.napaonline.com/Catalog/Re...2040%205999999
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
i just replaced mine with a cut to fit from advanced auto parts. i had to trim about 2 inches off the radiator side. it fits just about perfect. try there? hose had a carquest label on it
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
I remember o reileys having both the lower and uppers listed on their site. One is common stock and the other is something they usually only have at their busiest stores. You can try them. I did the search for a 305 TBI
IWANNAROCAGAIN
51
03-10-2016 07:07 PM
91TTOPZ
10-14-2015 06:01 PM
