Moates prom adapter won't fit in 165 ecm
Car: check
Engine: check
Transmission: check
Re: Moates prom adapter won't fit in 165 ecm
The cold start injector can't be disabled via the PROM/calibration. That system is independent from the ECM.
RBob.
RBob.
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
If I may clarify this, the 9th cold start injector is independent of the ECM BUT, the ECM needs to be re-calibrated for more cranking fuel to replace the added fuel from the 9th injector. The 9th injector delete is beyond just adding the extra fuel via re-calibration as the 9th injector must be unplugged (at the least) or completely removed and ports plugged as is typical for this mod. HTH!
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
This is a possible sign of the ECM not running off the prom. Be sure you have the prom seated into the adapter correctly and the adapter correctly seated into the socket on the ECM.
I have it unplugged for now. Not going to remove the injector though, I plan on doing a carbed 383 in the next few years, this chip was just to get me buy until then. Thanks again
Car: check
Engine: check
Transmission: check
And also thanks for clarifying what Rbob said. It mimics the 89 maf tpi cars way of adding a little extra fuel to each cylinder instead of using the ninth injector.
RBob.
