V6 owners, take a look
Old 10-01-2013, 08:36 AM
  #401
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Re: V6 owners, take a look
I think the stalling problem is fixed. It has been 4 days in cold starting weather and not one stall. Not sure what fixed it, but my guess would be one of the ECM pins was loose.
I removed the P.S. switch connector, EGR connectors.
I got rid of DFCO (going to try it again soon to determine if it was in fact an ECM pin).
I removed the ZIF socket and re-installed; Also, I removed about 20-30 ECM terminals and crimped them a little and pushed the tabs out more to make sure they are seated nice and tight.
I'll update after I enable DFCO, thanks guys! (bl85c and RBob especially!)
Old 10-01-2013, 06:03 PM
  #402
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Good to hear, enjoy tuning the '165!
Old 02-05-2014, 12:22 AM
  #403
bl85c's Avatar
Car: '85 maro
I did this awhile ago, but anyone interested in writing their own code should check this out.
Old 02-19-2014, 03:02 PM
  #404
bl85c's Avatar
Car: '85 maro
Anyone using PA6E, are you more interested in a 3 bar or 2 bar map? Both can be had cheap now, but 2 bar will give better resolution.
Old 05-20-2015, 11:42 PM
  #405
bl85c's Avatar
Car: '85 maro
I've picked this project up again while I have a bit of free time, hopefully I'll be able to release another version of PA6E with a couple things I was working on for version 2.0. The main difference between this and v1.2 will be an AFR based spark modifier table, an IAT spark retard table and minor stuff like a bit to modify the way the PWM table works.
I'm also thinking about writing code for E85 compatibility that will use a flex fuel sensor to adjust tables on the fly based on what's in your tank. That will probably be part of v3.0 though. If I'm left with enough time I'm going to do a modified version for v8's as well but I'm going to need a tester to help me with that.
txlegaldealer
07-08-2010 10:47 PM
305PhoenixAm
04-14-2005 05:27 PM
ctandc
08-27-2002 12:33 AM
87IROC350
07-06-2002 03:22 AM
Quick Reply: V6 owners, take a look
